ignition coil resistance
Old Jun 14, 2005 | 05:41 PM
HELICALB16's Avatar
Default ignition coil resistance
The honda manual calls for 12000-22000 oms of resistance across the secondary winding but when i check it it only has 9000 oms at around 80 degrees air temperature is it possible that this is a bad coil because the car has no spark .
The coil has 12 volts power going to it and the icm has power going to it also could this be a bad coil thank u for your help guys.
Old Jun 14, 2005 | 05:52 PM
neutron91's Avatar
Default Re: ignition coil resistance (HELICALB16)
it is more than likely bad... put in a new one
bbdrow
Jan 10, 2008 07:47 AM
ChilBlu92
Dec 28, 2006 06:35 PM
toooslow
Aug 20, 2003 09:12 PM
lucas569
Oct 4, 2001 08:56 PM
