ls/vtec qustion
Old Jun 14, 2005 | 04:35 PM
hondatuner20's Avatar
Default ls/vtec qustion
i know many people have written about th reliabilty of ls/tec engines. my ls has 120,000 miles. do you guys think it will blow up if i ls/vtec it with out replacing anything in the bottom end. i dont plan on reving past 7000? if not how many miles do u think ill get out of it before somthing goes?
Old Jun 14, 2005 | 04:37 PM
bottlefed13's Avatar
Default Re: ls/vtec qustion (hondatuner20)
do a leak down test first to find out if all the seals are still good.
Old Jun 14, 2005 | 05:13 PM
Default Re: ls/vtec qustion (bottlefed13)
i have done a leak down test and evrey thing is fine i did it about a month ago.
Old Jun 14, 2005 | 05:14 PM
Speed94's Avatar
i would replace the timing belt and water pump too while you're at it
Old Jun 14, 2005 | 06:12 PM
ITR420's Avatar
sad
Old Jun 14, 2005 | 06:25 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
replace the pistons too. 11:1+ compression > 9.2:1. as far as the rest of the bottom end goes, your stock internals will do fine up til 8000. a friend of mine has a 91 ls with a chipped ecu and he runs it up to 8000 with no problems. and he has 100k+ on it. plus the fact that your engine will be making its most usable power above 7000 anyway. good luck with the conversion; tell us how it goes after its done.
Old Jun 14, 2005 | 06:27 PM
Kendall's Avatar
Just curious as to why you want an LSV if you don't plan on spinning it over 7k.
Old Jun 14, 2005 | 06:35 PM
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Just curious as to why you want an LSV if you don't plan on spinning it over 7k.</TD></TR></TABLE>
exactly. even if you do stay in vtec while upshifting at 7000, your car is going to pull much harder 7000-8000. that is where all the hp is. and the peak torque might be above 7000 as well; someone correct me if im wrong.
Old Jun 14, 2005 | 06:39 PM
2GEN DA's Avatar
better off a low mile engine, i did mine at 110k and only got like 30k out of it but i was also using for races on street and strip!!!
Old Jun 14, 2005 | 06:44 PM
Default Re: ls/vtec qustion (Js2GEN)
well, low miles is always better. BUT, my 126,000 LS runs mint, with perfect compression across the board, and pretty good leakage test results. i am contemplating on doing the conversion to my car; not because of reliability/longevity, but because of my future financial situation.
Old Jun 14, 2005 | 06:50 PM
Default Re: ls/vtec qustion (benb18a)
well would i just be better of spending that money on stuff like a throttle body and a intake manifold with venom fuel ril and some crower stage 1 cams? im already running a 55 shot of zex. just lookin to hit like 180 whp with out my nitrous
Old Jun 14, 2005 | 06:57 PM
you will NEVAR hit 180 whp on an N/A LS. and no, dont buy the manifold. TB and IM will give you like 5-10 whp, and cost you 6-700 bucks. i say go with lsvtec if your engine is in very good running condition. you will hit well over 180 whp on a well tuned lsv with bolt ons and type r internals.
Old Jun 14, 2005 | 07:09 PM
90lsvtecteg's Avatar
I would say go ahead and freshen up the bottom end.But then it all depends on if you want reliability or you just wanna say hey i got an ls/vtec under the hood. Just do it right the first time and save yourself some money. just my opinion.Good luck.
Old Jun 14, 2005 | 07:50 PM
tegilator's Avatar
yea i would agree with do it right the first time. i spun a bearing in my ls and then i didnt turn the cranck when i replaced the bearings, and blew a big hole in the block, now i cant do ls vtec. so it will cost me for a whold new engine. so yea i would get the pistions and new bearings if you are going to be reving high
Old Jun 14, 2005 | 08:22 PM
ernald711's Avatar
you'll want to join the darkside of the 7k.
Old Jun 15, 2005 | 09:49 AM
mugenspoongsr's Avatar
Default Re: (ernald711)
would it be safe to put itr or ctr internals in that ls with a vtec head anr rev to 8000
dan's integra
Apr 18, 2006 09:36 PM
jdmwuuh02
May 23, 2005 01:38 PM
MugenB16A2
11
Jan 30, 2005 09:15 PM
1hotintegra
Jun 12, 2002 09:48 AM
Integra187
Jul 16, 2001 10:55 PM
