HOW DOES A RADIATOR FAN WORK
Old Jun 14, 2005 | 04:12 PM
95civickid's Avatar
Default HOW DOES A RADIATOR FAN WORK
HOW DOES A RADIATOR FAN WORK ON A 92-95 CIVIC IN ENETHER WORDS WUT MAKES IT TURN OFF AND ON?
Old Jun 14, 2005 | 04:35 PM
eg6T's Avatar
Default Re: HOW DOES A RADIATOR FAN WORK (95civickid)
ive never looked into it,but i guess that when the temperature goes up on the motor the ecu says "hey fan,your friend is getting a little hot,will you plaease do him a favor and cool him down." "sure"the fan says,"but i need some help".so the ecu sends him a little electricity to get the fan going."thanks" says the motor "i was starting to get hot"
Old Jun 14, 2005 | 04:36 PM
95civickid's Avatar
Default WUT MAKES THE RADIATOR FAN TURN ON IS IT FROM THE ECU
MY PROBLEM IS I HAVE A EF WITH A B16a2 AND THE BLOCK DOES NOT COME WITH A SENSOR TO TELL THE FAN TO COME ON OR OF THE EF SENSOR HAS TO PRAWNS ON THE SENSOR TO TELL IT TO TURN ON AND OF I NEED TO NO BECUASE I DID A 99 CONVERTION ON THE EF AND IM USEING A 92-95 RADIATOR AND THE FAN DOESNT WORK THE ONLY WAY FOR IT TO WORK IT TO GROUND IT BUT IF I DO THAT IT WILL STAY ON ALL THE TIME
Old Jun 14, 2005 | 04:38 PM
civiccpedx's Avatar
Default Re: WUT MAKES THE RADIATOR FAN TURN ON IS IT FROM THE ECU (95civickid)
you're gonna get yelled at for using all caps. but it is a sensor, and if you don't want it to run constantly your gonna need to get a new sensor from honda and put it in
Old Jun 14, 2005 | 04:39 PM
civiccpedx's Avatar
Default Re: HOW DOES A RADIATOR FAN WORK (eg6T)
quit making so many of the same posts
-reported
Old Jun 14, 2005 | 04:42 PM
Ricey McRicerton's Avatar
Default Re: HOW DOES A RADIATOR FAN WORK (civiccpedx)
Merged both of your Radiator fan threads.
P.S. Quit making new threads on the same topic.
P.S.S. Lose the caps.
naa10104
Honda CR-V & Element
May 7, 2018 02:03 PM
pali_paloza
Dec 30, 2011 06:13 PM
rasinhell
Jun 15, 2005 01:26 PM
