HOW DOES A RADIATOR FAN WORK
Re: HOW DOES A RADIATOR FAN WORK (95civickid)
ive never looked into it,but i guess that when the temperature goes up on the motor the ecu says "hey fan,your friend is getting a little hot,will you plaease do him a favor and cool him down." "sure"the fan says,"but i need some help".so the ecu sends him a little electricity to get the fan going."thanks" says the motor "i was starting to get hot"
WUT MAKES THE RADIATOR FAN TURN ON IS IT FROM THE ECU
MY PROBLEM IS I HAVE A EF WITH A B16a2 AND THE BLOCK DOES NOT COME WITH A SENSOR TO TELL THE FAN TO COME ON OR OF THE EF SENSOR HAS TO PRAWNS ON THE SENSOR TO TELL IT TO TURN ON AND OF I NEED TO NO BECUASE I DID A 99 CONVERTION ON THE EF AND IM USEING A 92-95 RADIATOR AND THE FAN DOESNT WORK THE ONLY WAY FOR IT TO WORK IT TO GROUND IT BUT IF I DO THAT IT WILL STAY ON ALL THE TIME
Re: WUT MAKES THE RADIATOR FAN TURN ON IS IT FROM THE ECU (95civickid)
you're gonna get yelled at for using all caps. but it is a sensor, and if you don't want it to run constantly your gonna need to get a new sensor from honda and put it in
Re: HOW DOES A RADIATOR FAN WORK (civiccpedx)
Merged both of your Radiator fan threads.
P.S. Quit making new threads on the same topic.
P.S.S. Lose the caps.
