need a HO alternator fast!
Its taken me 4 yrs & 66k miles & 1.5kws to officially destroy my oem alternator. I need suggestions for an 01 dc2 gsr alternator that will power a system no less than 2000 watts. Any suggestions? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap716 »</TD></TR><TR><TD CLASS="quote">have u thought about getting that alternator rebuilt with a higher output?</TD></TR></TABLE>
Who can do that sort of job? Is it reliable?
Modified by tweekerz at 7:31 AM 6/15/2005
Check at your local alt. shops, they can tell you how much bigger, [more output] the stock alt. can be rewound to, it's about 10%, maybe a little more, it's limited by the case size, they will also have "bigger" alt. in stock, don't forget an amp that is 1000 watts RMS with 50% efficiency draws about 160A at peak output, [not all the time, probably averages less then half of that, depends on how loud you play it] your going to need a 200A or bigger alt., if you want it to keep up with a 2000 watt system
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">Check at your local alt. shops, they can tell you how much bigger, [more output] the stock alt. can be rewound to, it's about 10%, maybe a little more, it's limited by the case size, they will also have "bigger" alt. in stock, don't forget an amp that is 1000 watts RMS with 50% efficiency draws about 160A at peak output, [not all the time, probably averages less then half of that, depends on how loud you play it] your going to need a 200A or bigger alt., if you want it to keep up with a 2000 watt system
94</TD></TR></TABLE>
i figured that all along, with the 200amp+ alts. does anyone have experience, or recomendations of alternators with this capacity?
94</TD></TR></TABLE>i figured that all along, with the 200amp+ alts. does anyone have experience, or recomendations of alternators with this capacity?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweekerz »</TD></TR><TR><TD CLASS="quote">i figured that all along, with the 200amp+ alts. does anyone have experience, or recomendations of alternators with this capacity?</TD></TR></TABLE>
Ohio Generator. Top notch quality, build and output. Great guys and warranty as well, they take care of their customers and have been in the business for a long time now.
Just received my alternator from alterstart in the mail. Looks mighty nice. Won't be installed for about 2 weeks but, they cleaned it up real nice, re-built it to 150 A and they also give a test sheet with it showing the amount of amps produced at the rpm intervals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sopiwnykg »</TD></TR><TR><TD CLASS="quote">Just received my alternator from alterstart in the mail. Looks mighty nice. Won't be installed for about 2 weeks but, they cleaned it up real nice, re-built it to 150 A and they also give a test sheet with it showing the amount of amps produced at the rpm intervals.</TD></TR></TABLE>
How much did it set you back?
tim_r95
Jan 27, 2015 08:02 AM
