1994 integra LS Idle issues
Need a little help if anyone else had the same problem
Im working a 94 Integra LS.
The car was dead when it came in. The fuel filter was clogged so that was changed out. Then the car would turn on idle for a second and die out.
Diagnostics was ran on the car coming up with nothing.
Next step was to check the map sensor. I pulled the map plug off and turned the car on it runs. So I figured it was the map sensor... bought another one of those and did a reset on the ecu. The car turned on idled for a second and died out. Then I took the MAP out of a friends running car... it did the same thing turned on and died off.
Any clue what steps to take from here???
Any help with this is appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">try another ecu</TD></TR></TABLE>
adam00integra
Jan 2, 2012 10:03 PM
