Compression & Leak down test results...
Well I had it done today at a local shop. Here are the results:
Compression:
Cylinder #1: 152
Cylinder #2: 146
Cylinder #3: 142
Cylinder #4: 153
Leak Down:
Cylinder #1: 5% (some rings)
Cylinder #2: 13% (mostly rings, plug)
Cylinder #3: 10% (mostly rings)
Cylinder #4: 3-4% (some rings)
The guy who did the tests seemed pretty surprised at the results. The car is a 91' CRX Si (d16a6) w/ 150,000 miles on it. I plan on keeping it for a daily driver w/ the only mods being I/H/E and some suspension work for auto-x. In the next 2 or 3 years I would like to get a b16 and build it to swap...I'm in no hurry though. Would you spend any money on this engine, if so...what? What do you recommend to get it running as smoothly as possible for the next couple of years? Thanks for any suggestions
Compression:
Cylinder #1: 152
Cylinder #2: 146
Cylinder #3: 142
Cylinder #4: 153
Leak Down:
7rrivera7
Aug 30, 2007 09:24 AM
hondakevin21
16
Apr 25, 2006 07:43 PM
92integraVTECgsr
Nov 20, 2005 08:31 PM
