temp guage going up to hot, someone help please.
Old Jun 14, 2005 | 05:28 AM
-Darren-'s Avatar
Default temp gauge going up to hot, someone help please.
i have a 93 civic dx. i just changed the thermostat in march 2005 and all of a sudden the temp gauge is almost at H when i drive it.
is this a symptom of a headgasket failure on its way. i know that civics of this yr. are prone to headgasket failures, so could mines be on its way out?
Modified by -Darren- at 9:51 AM 6/14/2005
Old Jun 14, 2005 | 07:20 AM
Kendall's Avatar
Check for leaks around the thermostat. If none are present then check the other cooling system components. Are you blowing any smoke?
Old Jun 14, 2005 | 07:55 AM
snatch's Avatar
Default Re: (Kendall)
I figure you have been driving it for some time now since you replaced the thermostat roughly 3 months ago, but did you make sure to get all of the air out of the cooling system? Other than that, check for leaks as well.
Old Jun 14, 2005 | 08:19 AM
-Darren-'s Avatar
Default Re: (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">I figure you have been driving it for some time now since you replaced the thermostat roughly 3 months ago, but did you make sure to get all of the air out of the cooling system? Other than that, check for leaks as well.</TD></TR></TABLE>
i believe that might be the problem, i bled the system but i might've not done it right. i'm going to do it again and see what happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Check for leaks around the thermostat. If none are present then check the other cooling system components. Are you blowing any smoke?</TD></TR></TABLE>
no leaks and no smoke at the moment.
thanks everyone for your input, i'll try bleeding the system properly and go from there.
Old Jun 14, 2005 | 09:46 AM
pgpunkguy's Avatar
Default Re: (-Darren-)
just because you replaced the thermostat doesn't mean it's not bad...
it may also be possible that your radiator is clogged or your water pump is bad.
if it's a bad headgasket, you'll probably be blowing smoke and you should be able to notice your coolant level slowly diminishing...
floatfisher
May 19, 2007 04:20 AM
nonhondaman
Apr 17, 2007 07:26 PM
ge_itr
Dec 2, 2006 07:29 AM
ablack934doorcivic
Oct 13, 2006 04:43 PM
spoonfed95
Jun 5, 2003 09:31 PM
