Z6 swap question
Old Jun 14, 2005 | 12:24 AM
Crimson_Tide's Avatar
Default Z6 swap question
hey guys ill hopefully be swapping in a z6 into my '91 hatch std and was wondering what all needs to be done as far as wiring... ive heard of a few companies that sell the modified harnesses but was wondering if it is easy enough for me to do it myself... are the harnesses worth the money? this is my first swap so im not too knowledgable on this subject... is there a harness that i can buy that will take care of all the wiring work for me? how much are they? who makes the cheapest and/or best harness? thanks a lot for the info
-Josh
Old Jun 14, 2005 | 12:46 AM
crxnj's Avatar
Default Re: Z6 swap question (Crimson_Tide)
You have to convert your harness to mpfi,obd1,and add the wires for vtec..
Rywire.com can build you a harness if you cant do that **** yourself....
Old Jun 14, 2005 | 12:50 AM
Default Re: Z6 swap question (Mr.speaker)
yeah but dont i need to send them my harness and some other stuff too? i dont have any of that stuff and do their harnesses have everything i need? thanks
-Josh
Old Jun 14, 2005 | 12:59 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson_Tide &raquo;</TD></TR><TR><TD CLASS="quote">yeah but dont i need to send them my harness and some other stuff too? i dont have any of that stuff and do their harnesses have everything i need? thanks
-Josh</TD></TR></TABLE>
Taken from the site..
What I need from you:
- Un-modified DX/STD engine bay wire harness
AND
- Complete Si engine harness (You must buy the plugs below if you don't have this)
OR
- Injector resistor box (Add $25) [ ADD TO CART ]
- 4 OBD1 injector plugs (Add $10) [ ADD TO CART ]
- 4 Plug connector (Add $5) [ ADD TO CART ]
- 4 wire O2 Sensor (Add $5) [ ADD TO CART ]
- VTEC Oil Pressure Plug (Add $5) [ ADD TO CART ]
- VTEC Solenoid Plug (Add $5) [ ADD TO CART ]
- Injector Block-off Plug (Add $5) [ ADD TO CART ]
- Distributor Plugs (Add $5) [ ADD TO CART ]
What you will get:
You will send me your DX engine harness, and the D15b/D16z6 engine harness (or parts listed above), and I will send you back 1 complete modified DX/D15b Hybrid harness, a VTEC subharness, and directions for installation that can also be found on this website. You can have your scrap harness back upon request
Old Jun 14, 2005 | 01:03 AM
yeah i read that but i wasnt sure if that was neccesary or not... i dont have an si harness nor do i know of any places around here that carry them... is there any place where i can just send money and get the harness i need?
-Josh
Old Jun 14, 2005 | 01:04 AM
what about http://www.jkobd.com/0to1.htm ? it doesnt say on there that i need to send any harnesses... would this harness be the one i need?
-Josh
Old Jun 14, 2005 | 01:24 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson_Tide &raquo;</TD></TR><TR><TD CLASS="quote">yeah i read that but i wasnt sure if that was neccesary or not... i dont have an si harness nor do i know of any places around here that carry them... is there any place where i can just send money and get the harness i need?
You dont have to have an si harness..It says send in a si harness or buy the parts he needs to do the harness..Which is right on his site as an option..And his dx to obd1vtec harness includes the obd0-obd1 conversion harness from jkobd..
Look right here http://rywire.com/dxtodvtec.shtml
Old Jun 14, 2005 | 07:08 AM
ok i didnt understand that when i read it... so it would be $300 plus the $65 for all of the parts that he needs? damn i thought that a harness was going to be around $150 or something... lol guess i need to start scrounging some money... so are there any harnesses around that are cheaper? thanks for being so patient with me
-Josh
Old Jun 14, 2005 | 07:19 AM
crxnj's Avatar
Actually his stuff seems to be the cheapest online..And you can get everthing from one place..
You can always build your own if you're broke..All you really need is some wire,oem clips,some wire looms,and a guide to go by..
Old Jun 14, 2005 | 07:21 AM
yeah thanks anyways but that seems a lil too complicated for my first swap... want to keep it as simple as possible... lol... are there very many people that sell the harnesses after they swap to a completly different motor? where would be a good place to look? ebay? thanks
-Josh
Old Jun 14, 2005 | 07:26 AM
crxnj's Avatar
Sometimes you get lucky ..Check out Urbanracer.com,Hondaclassifieds.com,thepartstrader .com,and here..
Old Jun 14, 2005 | 07:28 AM
D15Bbigred's Avatar
actually its kind of straight forward, its 300 dollars total, i would get this if i was attempting this swap because this would make it easier than anything. all u need is a ecu from a 92-95 p28. and ur good too go
rustanghunter
Mar 26, 2010 07:58 PM
eg4usdm
Mar 17, 2005 04:25 PM
streetmodified
Jan 6, 2005 01:49 AM
Kendall
Feb 4, 2004 06:57 PM
guttedhatch
May 28, 2003 10:22 PM
