Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Big Weekend For The GSR
Old Feb 10, 2002 | 09:42 PM
Drew M's Avatar
New User
Default Big Weekend For The GSR
So I had this monumental list of **** I needed to do to the car, and it wasn't getting any smaller. A friend of mine decided to come up for the weekend so we could do some suspension swaps on our Cobras. I figured we could get some crap done on the race car as well. On Saturday Misa (SOHCkordVTEC) and Chris (not from this board) came up as well. Those 2 guys busted their asses while my friend Josh and I worked on the Mustangs. Here is what got accomplished this weekend:
- Suspension swap between 2 Mustangs (shocks, springs, CC plates)
- Installed MSD 6AL with cap and Blaster Coil (my non-revving V8 *** even had an 8k chip for the limiter)
- Cage removed from the GSR
- All the sound absorbing crap removed
- Interior was painted
- Door panels removed and switch panels relocated
- All upper plastic and headliner removed
- Sunroof removed, hole filled
- Cage reinstalled
- Timing belt/Water pump/tensioner replaced
All in all I think I shaved about 80-90lbs out of the car. I didn't take my camera to the garage so I couldn't get any pics but I will get some tomorrow night (for those who care). The window net and rollbar padding *should* be here tomorrow so that will go in as well. Once that stuff is in the only thing left is the seat/brace and the kill switch. The list is getting smaller!
[Modified by Cobra, 1:47 AM 2/11/2002]
Old Feb 10, 2002 | 09:52 PM
Nick M's Avatar
Default Re: Big Weekend For The GSR (Cobra)
Too bad I couldnt make it down there. Im sure we'll get other opportunities. Chris is on the board. His name is "Ceeveek", he has a total of 11 posts, all of which came tonight I think.
Old Feb 12, 2002 | 08:07 AM
Drew M's Avatar
New User
Here are some pics:
The new helmet - light as ****.
Painted back-half free of sound-absorbing crap
The pimpy roof panel (primered but not yet painted)
Roof panel from the inside
Hella tite grip tape. I opted to leave the padding on the firewall and the goop on the tunnel to try and reduce some in-car temperatures.
Old Feb 12, 2002 | 10:06 AM
krshultz's Avatar
1. Your spray paint job appears to have come out better, or at least shinier, than mine did. What did you use? I used Plasti-Kote from Auto Zone.
2. I'll be paying a lot of attention to your pimpy roof panel.
3. What did you do with your window controls - or have you not gotten that far yet?
--Karl, who is getting really, really tired of working on the car...
Old Feb 12, 2002 | 10:26 AM
Drew M's Avatar
New User
Default Re: Big Weekend For The GSR (krshultz)
1. Krylon Gloss White over a coat of Rustoleum flat white sealer
2. The panel came out much better than anticipated. I think I have a total of $35 invested in the materials. My only concern was wind buffeting at high speeds. I got it up to 95MPH last night and the panel didn't flap at all so it may not be a problem. The big thing I like about how I did it is that I drilled no holes in the actual roof of the car.
3. The window controls are mounted to the existing brackets that held the door panel on. If you remember the door pull handle/pocket screws to a bracket. I simply screwed the switches to that bracket. The driver's side required an additional piece of metal to keep it from swinging out towards the driver's seat. I used exhaust/stereo band for this. I will send pics of it to you tonight.
Cobra - Who still has an assload of stuff to do also
[Modified by Cobra, 2:28 PM 2/12/2002]
Old Feb 12, 2002 | 11:03 AM
martini's Avatar
cobra, what you did on the roof looks very similar to what I did on my..Though my is lexan, and is removable. I wish I had a better picture of it...but here:
http://www.fatboyraceworks.com/crx/i...e/DSCF0149.jpg
Old Feb 12, 2002 | 11:19 AM
Crack Monkey's Avatar
Are you allowed to run windows with no door panels? I'm pretty sure that is a NO-NO.
Old Feb 12, 2002 | 11:26 AM
Willard's Avatar
Default Re: Big Weekend For The GSR (Crack Monkey)
"- Interior panels, carpet, headliner, and sound deadening may be removed"
Will
Old Feb 12, 2002 | 11:46 AM
Default Re: Big Weekend For The GSR (Willard)
I see that. But, if the glass is in place and you get t-boned all that window glass is gonna fly all over the driver area. A door panel will help contain the broken glass to the door.
I know the GCR requires door to be completely gutted (so, to remove the panel, the glass must also be removed).
Old Feb 12, 2002 | 11:55 AM
Drew M's Avatar
New User
I know of several cars running with the glass in place but no door panels.
Old Feb 12, 2002 | 04:05 PM
sjasmund's Avatar
I don't know about the NASA rules but, for Improved Touring, you can remove the drivers door panel only if you have NASCAR door bars as part of your cage and the window removed. You're not allowed to remove the passenger side window and can only remove the door panel if you replace it with .060" aluminum.
Old Feb 12, 2002 | 04:31 PM
krshultz's Avatar
Default Re: Big Weekend For The GSR (sjasmund)
By "door panel" are we referring to the upholstered thing, or just to the metal skin behind it? Just want to make sure.
Old Feb 12, 2002 | 04:46 PM
Catch 22's Avatar
You will need something in place to keep the glass from covering the driver in case of an incident in the driver's door. The aforementioned aluminum panel would work just fine.
SleeperGSR
Apr 25, 2013 06:38 AM
deviate
Northern California (Sales)
May 2, 2007 09:04 AM
GSR in Progress
Jun 19, 2006 12:18 PM
89TSupra
15
Aug 5, 2004 07:50 AM
96_GSR
Jul 10, 2002 04:34 AM
