GSR rebuild question
Old Jun 13, 2005 | 06:14 PM
TylerC's Avatar
Default GSR rebuild question
I'm pickin up a GSR longblock this weekend w/ a fully rebuilt head, but the block has 100k, would you guys rebuild the block for good measure or if it looks decent throw it together and run it?
Old Jun 13, 2005 | 06:25 PM
rainforest's Avatar
Default Re: GSR rebuild question (TylerC)
do a cylinder leak down test to ensure everything is sealing, and then rotate the crankshaft if there is no binding you should be pretty good. if you really want to get in there check the bearings for unusual wear.
Old Jun 13, 2005 | 06:37 PM
slomofo's Avatar
GDD Member
I'd run it, but if your planning on leaving it in there for another 100k, i'd spend the extra $200 to have the block cleaned/honed, then throw some new rings, bearings, main seals, and oil pan gasket in.
Old Jun 13, 2005 | 08:02 PM
PrettyLude's Avatar
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">I'd run it, but if your planning on leaving it in there for another 100k, i'd spend the extra $200 to have the block cleaned/honed, then throw some new rings, bearings, main seals, and oil pan gasket in.</TD></TR></TABLE>
i'd do that too its convenient
Old Jun 13, 2005 | 08:12 PM
Kendall's Avatar
It's a lot easier to rebuild it out of the car than in the car.
Old Jun 13, 2005 | 08:19 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">It's a lot easier to rebuild it out of the car than in the car.</TD></TR></TABLE>
^^^The best advice IMO
Old Jun 14, 2005 | 07:17 AM
TylerC's Avatar
Default Re: (Lord Helmet)
thanks guys.
Old Jun 14, 2005 | 09:54 AM
pgpunkguy's Avatar
Default Re: (TylerC)
if you're gonna boost, i highly recommend you build it!
Old Jun 14, 2005 | 03:06 PM
dinko's Avatar
Default Re: (pgpunkguy)
rebuild it, save yourself the headache later down the road
AlAddiN|502
May 13, 2010 01:41 AM
ed4doorcivic
Nov 15, 2009 09:23 AM
thorclark
10
Aug 25, 2008 08:16 PM
knuckk
Jan 21, 2008 02:09 PM
BANting
17
Dec 31, 2004 01:40 PM
