92 main relay
where is the main relay on a 92 accord with a 2.2 im workin on one now and im a newbie with accords. Sorry if this is a stupid question but all help is appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90accorddx »</TD></TR><TR><TD CLASS="quote">wow there needs to be a forum just for this subject i think ive seen 10 times in the past two weeks </TD></TR></TABLE>
It's that time of year again.
Ok...If the car does not start, or starts only once in a while and you never done a distribuitor cap before, you may want to do that first (rotor too) .It happened to me when I had a 91 ...ad fixed it backwords : mayn relay, ignition module...and problem was the the distribuitor cap and the rotor... And usually, you cannot return electrical components... Just my $0.02
as far as the main relay, if the car starts after it has cooled down a bit after it has just been run, it is that the contacts on the main relay are worn down. just get it resoldered or get a new one. the distributor cap has nothing to do with a main relay. if it is a failing distirbutor cap you have a firing problem some where.
