???Crank Angle/flux Sensor???
Ok i am doing a b18b swap but the head is obd2 and the block is obd1 and i know basically the only thing missing is this crank angle sensor that obd2 blocks have. My question is should i attempt to buy that sensor or will i be straight without it?
BTW.....i am using my stock 00 dxy8 wiring harness and have a obd2 ls harness in the garage if that helps??
Help a brotha out!!!
I'm not 100% sure, but I was told me that it all depends on your ecu. I believe most if not all obd2 ecus look for the crank angle sensor thingies. I'm running an OBD2 engine w/a p28 w/o the crank sensor. Hope that helps.
By the way, I have the crank angle senor w/the wheel trigger thingie if you need one.
Oh one last thing, you might need a knock sensor too if the obd1 block didnt come with one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingElli »</TD></TR><TR><TD CLASS="quote">BTW.....i am using my stock 00 dxy8 wiring harness and have a obd2 ls harness in the garage if that helps??</TD></TR></TABLE>
No, it doesn't. What ECU are you using?
If you're using an OBD2 ECU, then yes you will need to install the CKF sensor.
obd1 p75 using a conversion harness. I know for a fact i can use the D16 harness just zip tie the vtec wires outta the way and convert to obd1 with a conversion harness plug in the obd1 ecu and done.
gustavito1986
Apr 6, 2008 08:52 AM
TheOwnrOfTheEk9
Mar 7, 2006 06:10 PM
