Toda vs DTR
Old Jun 13, 2005 | 04:25 PM
black2001ITR's Avatar
Default Toda vs DTR
I currently have the following setup
Well I run an all motor B18c with the following setup:
Toda pistons
Toda spec c cams
Heavily ported head
1mm oversized valves
Toda header
2.5in straight through exhaust
Stock intake manifold and TB
Now, my future setup is going to include the addition of Individual throttle bodies and a 70mm straight through exhaust with the toda header.
I was thinking of changing to a DTR header if it was would produce considerable gains over the toda.
Does anyone know what kind of gains the DTR header would provide over the Toda?
Any first hand experience?
Old Jun 13, 2005 | 05:21 PM
Kendall's Avatar
Unless you're having a header built specifically for your motor, I wouldn't think that any noticable gains will be had.
Old Jun 13, 2005 | 05:23 PM
Default Re: (Kendall)
that is what i was looking at getting done, do you think a custom built header would offer much more though?
Old Jun 13, 2005 | 06:59 PM
HONDA_TYPE_R's Avatar
Default Re: (black2001ITR)
My friend installed a DTR header on his 00 JDM ITR motor and saw an 6whp gain over the stock 2.5" collector'd ITR header with a bad thermostat and on a dyno that reads 5whp lower (or very near) than the one he originally did his baseline on. My advice...one, stick with the same dyno. Two...I have heard nothing but good things about the power gains from the DTR, SMSP and Hytech headers, get one! They're expensive though.
Old Jun 13, 2005 | 07:13 PM
Default Re: (HONDA_TYPE_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R &raquo;</TD></TR><TR><TD CLASS="quote">My friend installed a DTR header on his 00 JDM ITR motor and saw an 6whp gain over the stock 2.5" collector'd ITR header with a bad thermostat and on a dyno that reads 5whp lower (or very near) than the one he originally did his baseline on. My advice...one, stick with the same dyno. Two...I have heard nothing but good things about the power gains from the DTR, SMSP and Hytech headers, get one! They're expensive though.</TD></TR></TABLE>
sorry mate, that doesnt really help, i am after specific information for all motor setups and how the DTR benifits these setups more than the Toda
Old Jun 13, 2005 | 07:46 PM
onepoint6i's Avatar
theres no comparison between a DTR custom header and a toda header...DTR is custom made to the specs of YOUR engine....you get what you pay for..Toda is a nice header just not a DTR..
Old Jun 15, 2005 | 08:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black2001ITR &raquo;</TD></TR><TR><TD CLASS="quote">
sorry mate, that doesnt really help, i am after specific information for all motor setups and how the DTR benifits these setups more than the Toda</TD></TR></TABLE>
Buy the two and compare them on a dyno. If it was me, I would get the DTR from the results and praise I have seen and heard. If your that serious, search around, a dyno sheet may be out there comparing the two.
Old Jun 15, 2005 | 08:30 PM
VtecKiDD's Avatar
RMF header would be my choice
but
DTR is a great header
my personal choices would be
RMF narrow
RMF Race
SMSP 4-1
SMSP4-2-1
DTR production
ANR merge
DTRs custom headers i have not dynoed, id love to though
you cant go wrong with any of these, and i wold choose any of these over a toda
Old Jun 15, 2005 | 09:18 PM
VTECJUN's Avatar
Default Re: (VtecKiDD)
When buying a Toda header it is a mass production header. If you have DTR build you one it will be made specifically for you setup. There are so many different ways to build a header for a certain motor. If you have Danny build you one have confidence that he has built tons of headers, and that he has the track experience and knowledge of what works and what doesnt work on certain combinations. I would definitely go with the DTR if you are looking to maximize the potential of your setup.
DTR
Old Jun 15, 2005 | 11:31 PM
The Tea-father's Avatar
Default Re: (VTECJUN)
don't forget Toda is a road race company, they design are for road courses. Depends on what you are doing with your car, if you're using it for road race like me i go with Toda header. I have a 2 liters type r with toda c 12.5, toda header, valve trains and itb.
Old Jun 16, 2005 | 08:59 AM
UncleD's Avatar
Default Re: (The Tea-father)
A few dyno's I found....
Here are the specs on the engine that each header was run on:
- 1.8l gsr block
- .025” overbore integra type r pistons
- integra type r head
- integra type r intake manifold
- accel 255cc injectors
- overbore civic si throttle body
- injen short ram intake with filter removed
- b&m fuel pressure regulator
- titan motorsports cam gears
- jun type II intake cam
- integra type r exhaust cam
- all dyno runs were made open header
Hope this helps Keep in mind though that this is not his new "b unit" manifold, it was his older style that was used.
Old Jul 7, 2005 | 01:23 PM
NiceDc2r's Avatar
Default Re: (clean rice)
Comptech Race is an Awsome header as you can see by he dyno's posted earlier in the thread..we sell them for $875 Shipped to your door
Old Jul 7, 2005 | 01:24 PM
NiceDc2r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">A few dyno's I found....
- 1.8l gsr block
Hope this helps Keep in mind though that this is not his new "b unit" manifold, it was his older style that was used.</TD></TR></TABLE>
Old Jul 7, 2005 | 01:31 PM
Supernatural's Avatar
Default Re: (NiceDc2r)
you brought this thread all the back just to tell everyone that u are selling them....
thats a no no.....
and your talking about a header that has nothing to do with the topic
Modified by SUPERNATURAL at 10:56 PM 7/7/2005
Old Jul 7, 2005 | 04:23 PM
f@sth@tch89's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Tea-father &raquo;</TD></TR><TR><TD CLASS="quote">don't forget Toda is a road race company, they design are for road courses.</TD></TR></TABLE>
along with spoon, mugen, and comptech...all road race companies. JDM cant help u drag race.
Go custom you will like it.
Johnny_9
Mar 12, 2011 08:30 PM
Teamdiesel
Jan 15, 2007 05:14 PM
TsukubaSpec
10
Dec 11, 2004 08:38 PM
SpoonFed
Jun 12, 2002 09:50 AM
