I need your help! Code 22 - VTEC oil pressure switch - Defective circuit or unplugged
Old Jun 13, 2005 | 02:26 PM
b16ek4's Avatar
Default I need your help! Code 22 - VTEC oil pressure switch - Defective circuit or unplugged
I had an B16A2 swap from a '00 Si in to a 97 hatchback with a 98 GSR ECU. They used my stock wiring harness and just added the necessary wiring for a VTEC swap. They had my car running but it was throwing out all kinds of codes; IAT sensor, MAP sensor and etc.... I took it back to the shop and had the wiring fixed. So, the codes was gone and my car was running good. But a week after that I was driving on the freeway and my CEL came on and it was throwing out Code22 - VTEC pressure switch. So I took it back again to the shop and they re-wired the switch ground wire directly to my engine ground and reset my ecu. I test drove it again and the CEL came back again on 5th gear @ 4,500rpm (90mph). This time they open up the whole vtec spool assembly and clean the oil screen and they gave me a new ECU. My CEL would still come on. I dont have a problem with my motor on 1st-3rd gear. 4th gear my motor will engage VTEC (4500rpm) but as soon as i hit 90mph my CEL would come and throw out Code 22. 5th gear my VTEC wont even engage as soon as I hit the VTEC point (4500rpm) my CEL would come on and throw out the same code. I've already have my VTEC pressure switch replaced, my oil pump replaced, and my ECU replaced, still having the same problem. I've talked to the guy that did my motor swap, he said its the wirings. But everytime I call him up to get my car done he never answer my calls and I left him a dozens of messages already. Can anybody give me an instructions how to check my wirings. There's nothing wrong with my wires, I've already test it with the multimeter and i have a voltage current from end to end of the wires.
Thnx a lot!!
Old Jun 14, 2005 | 02:25 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: I need your help! Code 22 - VTEC oil pressure switch - Defective circuit or unplugged (b16ek4)
I just recently started up a new swap and I got the same issue.
I looked thru all these threads so maybe they will do you some help:
https://honda-tech.com/zerothread?id=1034175
https://honda-tech.com/zerothread?id=984842
https://honda-tech.com/zerothread?id=769943
https://honda-tech.com/zerothread?id=225481
Turns out I didn't need it. I checked the vtec plug and it was broken in half and super glued together. Last time I get a swap off H-T.
Old Jun 20, 2005 | 07:23 AM
b16ek4's Avatar
got the problem fixed! turns out that the pin was halfway inserted, there's only a little bit contact on the wires.
tamadrummer1120
Sep 17, 2009 09:20 PM
Dekorum
13
Mar 21, 2009 10:08 PM
lshatch92
Mar 27, 2006 10:04 AM
cioli
12
Feb 26, 2006 08:31 AM
h-t sucks
Feb 2, 2006 02:34 AM
