Bogging on first start up of the day
I just replace my injectors with a set that has been cleaned and balanced and matching spray pattern...
After the install it bogging bad (sounded like it was running on 3cyl.) for about 30sec straight....(I was saying to myself... **** I did something wrong... but lucky me the idle evened out and ran perfect after the fuel pressure got back up)...
the good new is all my bogging is gone and my idle is perfect now...
but my problem is if I first start my car after not driving it for maybe 8+ hours it boggs (bog bog bog 3 times <2sec) on initial start up, but after that and after warm up its all fine and if I restart with engine warm it doesn't do it)............. what should I check it's like my 1 or 2 injector are just waking up....
My setup :
B17/ctr pistons, vafc, fpr at @45psi, ngk 7's, new dizzy....etc
My setup :
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6hatch3 »</TD></TR><TR><TD CLASS="quote">check your fuel regulator.</TD></TR></TABLE>
where is this regulator located...
what should my fuel pressure be at when I prime it for the first time....mines showing around 42psi before I start it...
