92 lude fuel pump location
Old Jun 13, 2005 | 12:22 PM
bigbacon2's Avatar
Default 92 lude fuel pump location
i was wondering if anyone knows exactly how to find and change out the fuel pump?? do i need to drop the gas tank? i searched but found nothing please help
Old Jun 13, 2005 | 12:38 PM
Hawkze_2.3's Avatar
Default Re: 92 lude fuel pump location (bigbacon2)
Take out the back seats and there is a metal cover. Remove this and you have easy access to the fuel pump, no need to drop the tank.
Old Jun 13, 2005 | 12:42 PM
bigbacon2's Avatar
Default Re: 92 lude fuel pump location (Hawkze_2.3)
thnks also do u know if the fuel pump relay is right there 2????
Old Jun 13, 2005 | 12:57 PM
pentaq's Avatar
no it's not there. fuel pump relay is under console.
Old Jun 14, 2005 | 12:22 AM
Freddiesluda's Avatar
Default Re: 92 lude fuel pump location (pentaq)
actually there is no fuel pump relay its the main relay... just letting you know... cause i spent hours looking for it and finally figured my friend told me that on purpose.
Old Jun 14, 2005 | 01:08 AM
flip1199's Avatar
Default Re: 92 lude fuel pump location (Freddiesluda)
you also shouldnt have to remove the back seat, just everything in the trunk. if u feel like driving down to sac i'll do it for you for 20 bucks and a burrito..
Old Jun 14, 2005 | 07:02 AM
SKDRCR's Avatar
Default Re: 92 lude fuel pump location (flip1199)
Are you sure the fuel pump is the problem or are you
putting in a warlbro or something.
The stock fuel pump hardly ever goes out.
Old Mar 1, 2006 | 06:59 PM
bburtonsk8r2's Avatar
Default Re: 92 lude fuel pump location (SKDRCR)
stock fuel pump rarely goes out? i have a 92 lude, and the car was sitting for almost a year, 16 years old, and i cant hear it turning on, u think this could be the relay or the pump, i put a guage on and now im getting no psi, i bought a walbro which i would have to soon enough anyway, but how possible is it that the relay is blown?, battery was disconnected when i mounted gauge on the filter, and everything is good with no leaks, pretty sure its the pump.
Old Mar 1, 2006 | 09:10 PM
Sabbotage's Avatar
Default Re: 92 lude fuel pump location (bburtonsk8r2)
Im willing to bet its the main relay thats bad. You can pull them out and resolder the connections and revive them a lot of times. Thats what i did with mine.
Old Mar 2, 2006 | 04:27 AM
kulrevon's Avatar
to check if its your relay turn you key to the on position. the check engine light should come on for a sec then shut off. if it doesn't turn off It is almost definate that it is your main relay. If it stays on hit or kick the dash by your left foot. the light will flicker or go off. when it goes off try to start the car. it probably will start.
Old Mar 3, 2006 | 02:42 PM
Default Re: 92 lude fuel pump location (kulrevon)
thanks guys, i actually just put my walbro in today and everything is good now, i guess the 16 year old pump with 150000 miles had had enough. i was suprised how much smaller the 255 walbro is compared to stock fuel pump. it was kind of a pain to put in but only took about 1 hr.
Old Mar 3, 2006 | 02:46 PM
when u pull the whole assembly out of the top of the tank it is a lil tricky, if u take both rear seats out and some other things u can take out that cross brace that kind of gets in the way, i was able to fit it around somehow, but it was lil hard to fit it back in, loosen all the 10s on the top, when doing a walbro, u have to hardwire the pump, use all the new hardware and mount it on the bracket, pretty simple, some people zip tie the pump to stay in place but mine was solid as **** just with the hose on the top. it wasnt that bad if u have some mechanical experience, i only have intake, exhaust, header, wires, and fpr and the 255 high pressure pump put my fuel pressure right around 39, car fired right up and runs good.
Old Mar 3, 2006 | 02:52 PM
JG Luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote"> If it stays on hit or kick the dash by your left foot. the light will flicker or go off. when it goes off try to start the car. it probably will start.</TD></TR></TABLE>
Finally, someone else that understands that you have to intimidate your car.
"five across the eyes."
hatchBK4life
Aug 2, 2010 05:11 PM
GDM S2K
Honda S2000
Jan 8, 2007 01:30 PM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
94teggyls
Jun 14, 2003 09:01 PM
