Got another one for you all
Passenger window is not working on the lude.
(Power windows) I hit the window switch and nothing
no sound or anything. I checked the fuse and it’s good. What
else could it be?
else could it be?
both windows? or just one? if both arent working it sounds like a wiring problem. On my RX7, if one of the switches wasnt connected, or wasnt passing electricity through it, neither switch would work. Check the switches (if the fuse is good)
Neil
Neil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">This might sound dumb but are you sure the power button on the driver's side control panel is on??</TD></TR></TABLE>
hehe i wish it was that simple.
its only the one side.
Only the one side? OK, how about the control on the other door. Does that not make the window go up or down either - as in, you can't get it to work from either door? Sometimes the metal contacts in the switches get's all fouled and gummed up, and either need cleaned or replaced. Also, pull the switch from the door panel and make sure the plug is seated securely in it's socket...
