Going from neuspeed race to skunk2 coilovers?!?
Old Jun 13, 2005 | 09:50 AM
Project_EK's Avatar
Default Going from neuspeed race to skunk2 coilovers?!?
What up,
I currently have neuspeed race springs on my car, with OEM struts. Honestly the ride is a little bouncy but it's not that bad at all! I found a really good deal on some skunk2 coilovers so i picked them up! I was wondering if i replaced the race springs with the skunk2 coilovers would the ride be alot worse? or about the same? The reason i wanna put the skunks on, is because i want to go about a 1/2" lower..
lemme know
BTW: is anyone ridin on skunk2's with oem struts?
Old Jun 13, 2005 | 10:05 AM
solareclipseauto's Avatar
Default Re: Going from neuspeed race to skunk2 coilovers?!? (EKhatch219)
its hard to say if the ride is gonna be any worse or better without seeing how it is now. i would think it might be worse with the coilovers because it sounds like your shocks might be blown but like you said you wanna go 1/2" lower. i would of bought some koni yellows because you can adjust the ride height by dropping the bottom spring perch.
Old Jun 13, 2005 | 10:11 AM
Project_EK's Avatar
Yea..i was going to buy some struts, But like i said with the race springs its not that bad at all!
Old Jun 13, 2005 | 10:27 AM
Project_EK's Avatar
bump
Old Jun 13, 2005 | 10:31 AM
snatch's Avatar
Default Re: (EKhatch219)
From my experience Skunk 2 coilovers will be fairly bouncy. It can be a tad better if you get some good shocks to throw with them though, Koni Yellows or something adjustable.
Old Jun 13, 2005 | 10:32 AM
Project_EK's Avatar
thanks...keep it coming
Old Jun 13, 2005 | 10:57 AM
POE's Avatar
POE
dont buy those coil overs if i were u , and i would save the money and buy some kyb agx shocks, i have the same setup race springs with kyb agx, ride awesome! make sure u cut your bump stops also!
if u want to go LOWER than u allready are with the Race springs on stock shocks, your ride is going to be worse, most deff, and your shocks will blow sooner, if they havent allready.
jdmstreethatch
Mar 24, 2004 08:15 AM
sjteg
Aug 8, 2003 10:27 AM
AcuraEL
17
Jul 29, 2003 07:44 AM
MooreBoost
Jul 22, 2003 09:45 AM
wizzards581
May 14, 2002 10:07 AM
