Going from neuspeed race to skunk2 coilovers?!?
What up,
I currently have neuspeed race springs on my car, with OEM struts. Honestly the ride is a little bouncy but it's not that bad at all! I found a really good deal on some skunk2 coilovers so i picked them up! I was wondering if i replaced the race springs with the skunk2 coilovers would the ride be alot worse? or about the same? The reason i wanna put the skunks on, is because i want to go about a 1/2" lower..
lemme know
BTW: is anyone ridin on skunk2's with oem struts?
lemme know
Re: Going from neuspeed race to skunk2 coilovers?!? (EKhatch219)
its hard to say if the ride is gonna be any worse or better without seeing how it is now. i would think it might be worse with the coilovers because it sounds like your shocks might be blown but like you said you wanna go 1/2" lower. i would of bought some koni yellows because you can adjust the ride height by dropping the bottom spring perch.
Re: (EKhatch219)
From my experience Skunk 2 coilovers will be fairly bouncy. It can be a tad better if you get some good shocks to throw with them though, Koni Yellows or something adjustable.
dont buy those coil overs if i were u , and i would save the money and buy some kyb agx shocks, i have the same setup race springs with kyb agx, ride awesome! make sure u cut your bump stops also!
if u want to go LOWER than u allready are with the Race springs on stock shocks, your ride is going to be worse, most deff, and your shocks will blow sooner, if they havent allready.
jdmstreethatch
03-24-2004 08:15 AM
AcuraEL
17
07-29-2003 07:44 AM
wizzards581
05-14-2002 10:07 AM
