96 LS climate control
How do I take the climate controls out....or rather....where is the screw that is holding it in located at. I installed a VAFC2 and have to run the wires down there. It looks kinda fugly just hanging out lol. Thanks
you have to pull the hazard/defroster buttons out, and there are screws behind them (these are a pain in the *** so be carefull). Other than that it is just clipped in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack »</TD></TR><TR><TD CLASS="quote">you have to pull the hazard/defroster buttons out, and there are screws behind them (these are a pain in the *** so be carefull). Other than that it is just clipped in</TD></TR></TABLE>
snapping out the hazard/defroster buttons, and then unscrewing the screws behind them is the easier part. Then Unhooking the temperature cable can be a pain...then you have to unplug the blower switch harness...at this point it will slide cleanly out.
but since you are just running wires you might not need to completely pull it out, you should have enough room to manuever by just unscrewing the two screws and partially sliding it out.
GL.
GL.
PINKS
105
Dec 23, 2009 08:54 AM
caspers_hatch
Jan 19, 2007 11:42 AM
lakerschamp2000
May 9, 2005 09:26 PM
