What headers to get most POWER from a JDM B16a in 94 SI
Looking to get some after market header's for my JDM B16A in my 94 SI. I want to buy headers that will give my car some power i was think about the TYPE R JDM 4 TO 1's. Can you guys in here give me some suggestions. I have and LSD trans with a Lightened Flywheel and a Stock clutch. I plan on putting some Civic type r cams and a Type R Intake Manifold that i will probally modify. and a 68mm Throttle Body. I have a Chipped Ecu and a Full upgraded ApexI Exhaust System. With this type of setup looking for the Best header that will add to my motors Performance.
You have A/C? Do you want to keep it if you have it? Most of the better headers are not A/C compatible, and are quite pricey with still minimal gains.
My JDM ITR clears my AC just fine in my 92 CX. No PS. Import power house has a new RMF narrow style header that clears the AC:
http://www.importpowerhouse.co...s.htm#
Check out this awesome header test:
http://www.tunerzine.com/news/....html
defiantly not, the compact version which is that crazy twisty one is p/s compatible not a/c compatible
edit: then there is the full race version from a few companies that stick out like 8 inches stright out from the head lol
edit #2:but then you need to rev the **** out of the motor to realize the gains
AN-R do one that is made for thicker core rad, looks funky but may not fit with a/c not sure check their site out, its pretty detailed.
sam
sam
A/C NOT AT THE MOMENT HAVE TO PURCHASE THE DEL SOL BRACKET, BUTR THE WAY THE SUMMER IS GOING I THINK I MIGHT HAVE TO GET THE A/C IN THERE.
They have some pretty vicious heades on that site i'm really admiring the unique design's they manufacture these headers in. thanks for the input
if i was you i wouldnt look for the header that makes the most peak power but the one with a better torque curve...especially since it is a b16 i would try to get every last bit of torque out of it...do u only want a 4-1??because spark racing has a new 4-2-1 that is making very impressive numbers on a relatively stock b16....im currently saving up for one of those for my b16 ef...oh those an-r compacts are sick...but i havent found a single dyno graph for one on a b16
https://honda-tech.com/zerothread?id=1266654...
the ground clearance is awesome...i know that it fits in an ef so it will fit an eg easily
IH82LOSE
Oct 12, 2003 10:59 PM
