car starts and dies
Old Jun 13, 2005 | 05:36 AM
PearlWhiteAccord's Avatar
Default car starts and dies
have a 93 sol si automatic, it starts then dies immediately...happned before, but it starts right up after a few minutes.
plugs, distributer, were changed 5k miles ago....fuel pump, i hear turn on but i do smell gas. Please help
Old Jun 13, 2005 | 05:45 AM
ekb16's Avatar
iac or map sensor maybe...same thing is happening to mine also
Old Jun 13, 2005 | 06:05 AM
Default Re: (ekb16)
anway to troubleshoot???
Old Jun 13, 2005 | 07:06 AM
supaman111's Avatar
Default Re: (PearlWhiteAccord)
That sounds like your Fuel Relay, cost a bomb to replace from honda, but can be repaired with solder. This happened to 2 or my cars and both it was fuel relay. it was a honda technincian who told me about the fault and he managed to repair both with solder as he is a friend.
hope this helps
sam
Old Jun 13, 2005 | 08:17 AM
Default Re: (supaman111)
where and how do i find the fuel relay???? or the other stuff...my car acted up on me before, but this time it just wont start.....
i will try later tonite, it might need a rest, i hope....
oh, what are signs of timing belt snapping, what symptoms???
Old Jun 13, 2005 | 09:05 AM
supaman111's Avatar
Yeh that sounds exactly like Fuel Relay or Distrubtor, when you turn the ignition on you should here the fuel pump, if you don't here this then it is definatley fuel relay, if you do here the pump and it wont start then it will be distributor. This is assuming your plugs, leads, distributor rotor arm and cap are fine.
Fuel relay is located under the dash, in the UK (Right hand drive) it is under the driver side dash where the bonnet pull is, never seen a left hand drive but should think it is exactly the same.
you can never tell when timing belt is going to snap unless u pull the rocker cover off to see if it has begun to split!!!!
sam
Old Jun 13, 2005 | 10:21 AM
I hear the fuel pump turning on...but not sure about the distributor now...
Old Jun 13, 2005 | 01:31 PM
supaman111's Avatar
Then it will be distributor, they go around 100,000 mile dont know what that would be in kilometers.
Personally i think it is distributor if you hear fuel pump and it dont start. You will have to buy a recon or new distributor as the bearigs inside them go. i got mine imported from America through Distributor King.
Both would be a quick fix and cheap if you go to a Honda specialist.
sam
Old Jun 13, 2005 | 01:33 PM
Can i check distributer myself?? and how??
my sol has 154k miles, but the distributer looks new or changed before i bought it 2 yrs ago
Old Jun 13, 2005 | 11:13 PM
supaman111's Avatar
not much goes wrong on these engine, distributor is the only guaranteed part to go wrong, the symptons say to me distributor, the way i tested mine was borrowed the dizzy off a mates car and tried it on mine. Otherwise you would have to take it to a garage.
sam
Old Jun 13, 2005 | 11:43 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
pretty sure it has to do with the fuel, full the rail and check if the injectors are firing. Could be a leak in the fuel return, injector leak?
Old Jun 14, 2005 | 01:40 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PearlWhiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">I hear the fuel pump turning on...but not sure about the distributor now...</TD></TR></TABLE>
Just keep an eye on your check engine light. Next time you drive the car or this happens make sure to listen for that. It sounds like the Main Relay (what he is referring to as Fuel Relay) and not the distributor. Are you having problems with it on days when it is rather hot outside. Make sure you can always hear the sound again when it doesn't start.
Old Jun 14, 2005 | 01:55 AM
egtwincam's Avatar
Default Re: car starts and dies (PearlWhiteAccord)
smell fuel? i hope your not smelling it out of the gas cap?
If your smelling fuel..you got a leak and that can cause your engine to stall from lack of fuel psi.
Old Jun 14, 2005 | 05:53 AM
Default Re: car starts and dies (egtwincam)
cant drive car since it wont start up again..
took the dist. cap off, everything looks fine..
still hear fuel pump turning on when i turn key..
but now car doesnt start and die, it just cranks...
Old Jun 14, 2005 | 06:29 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
If you smell gas that means it isn't gettin burned, hondas got dual relay. The first relay powers up the computer and supplies power for the second relay. Once the computer is powered up, it will ground the second relay, which supplies power to the fuel pump. So if you can hear your fuel pump prime, you can eliminate the main relay/fuelpump/fuel relay problems.
It sounds more to me like a bad map sensor since you're saying it starts and eventually dies. ALso since you're smelling fuel, it prolly isn'y being burned due to spark problems. Try cranking it again then give it some gas. If it still doesn't start, pull the plugs see if its fuel fouled and trace it back from there.
Old Jun 14, 2005 | 07:55 AM
supaman111's Avatar
You will never be able to tell if the distributor is the problem by looking inside it. It is the bearings that go, these are located inside the rotating shaft, these wear and then oil enters all the electrics. Mine used to start up and then die when i had distributor problem, it got to a point also when it never started. I changed the coil pack inside the distributor and it worked fine for a while, then that coil got damaged by the oil, eventually i just brought a new distributor and it worked fine.
as you say you smell fuel then i would get that checked first before being sure about distributor.
do you have a dohc vtec??
sam
Modified by supaman111 at 5:14 PM 6/14/2005
Old Jun 14, 2005 | 08:00 AM
cuin9sec
Guest
Posts: n/a
did you put gas in ???
Old Jun 14, 2005 | 08:15 AM
supaman111's Avatar
Default Re: (t67civic)
obvious........... but not so obvious
Old Jun 14, 2005 | 08:21 AM
still got about a 1/4 tank in...
it doesnt start anymore, just cranks....
will pull the plugs tonite and see...
Old Jun 15, 2005 | 03:22 PM
egtwincam's Avatar
check for spark when you crank the engine... if you got spark then check for fuel pressure...
Old Jun 17, 2005 | 07:18 AM
Default Re: (egtwincam)
checked yesterday nite, had spark from plug wire to screwdriver to chasis ground...
i open up my gas cover and lot of pressure came out....
any suggestions?? should it be my fuel pump??
Old Jun 18, 2005 | 09:50 PM
Update, fixed...flooded the engine fouling spark plugs, and continual cranking caused timing belt to jumped a tooth
Old Jun 21, 2005 | 11:59 PM
egtwincam's Avatar
that musta been some serious flooding to jump the timing belt a tooth..unless your belt was loose in the first place and jumped in the beginning.
Good news its fixed
allmotor2.1
Nov 24, 2007 04:52 AM
cybercg
Sep 10, 2006 05:20 PM
uszcrx
24
Sep 9, 2006 01:05 PM
stevescivic
Jul 3, 2004 06:48 PM
mgries
Sep 19, 2002 07:15 PM
