D16 intake on D15 problems
Old Jun 12, 2005 | 06:06 PM
lowmitsu's Avatar
Default D16 intake on D15 problems
94 cx model / everthing bolts on fine but engine idle surges & i have one coolant port that has nowhere to go... has anyone on here tried this near pointless swap..
the coolant i could probably cap it off..but i dont know why the surging after i rev it say to 2500rpm it calms down then surges back up once..
Old Jun 12, 2005 | 06:14 PM
EK k kay's Avatar
Default Re: D16 intake on D15 problems (lowmitsu)
Vacuum leak.
Old Jun 12, 2005 | 06:33 PM
DISROK1's Avatar
i did the same swap on my cx. did u use new gaskets?
Old Jun 12, 2005 | 06:56 PM
lowmitsu's Avatar
yes i used a brand new gasket . my d15 gasket fell apart so I bought one for the d16....
Old Jun 12, 2005 | 07:26 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
did u scrape the old gasket off really good or its the iac on the d16 manny
Old Jun 12, 2005 | 07:31 PM
lowmitsu's Avatar
i cleaned it quite well ..i swapped all my stock sensors,beacause they worked fine before but it didnt seem to change anything..i'm not a mechanic by any means really & i'm not sure which one is the iac,I believe that is the closest one to the throttle body....
Old Jun 12, 2005 | 07:48 PM
yeah on the back of the manny but i would say u have a vac leak somewhere
Old Jun 12, 2005 | 08:01 PM
lowmitsu's Avatar
guess i'll buy a can of carb spray & blast it till i find it after work 2marrow...
Old Jun 12, 2005 | 08:23 PM
Redline96LX's Avatar
* B A N N E D *
D16 intake...?
Wanna tell us WHICH D16 Intake this is?
Are you refering to the plastic intake TUBE or the intake MANIFOLD?
Old Jun 12, 2005 | 08:33 PM
DISROK1's Avatar
Default Re: D16 intake on D15 problems (Redline96LX)
ANY D WILL SWAP EASY.
TRY FLUSHING YOUR RAD FLUID. YOU MIGHT HAVE AIR IN THE LINES.
Old Jun 13, 2005 | 01:58 AM
lowmitsu's Avatar
the intake is off of a 1616z6,And yes its the intake , why would I change the plastic tube??
95blackEG
Nov 24, 2007 07:29 AM
chu77
Jul 25, 2006 05:03 AM
SVOboy
10
Mar 24, 2006 07:07 PM
joecivic93
Jan 3, 2004 10:25 PM
Kevin
May 22, 2002 11:18 PM
