strange, radiator fan will not turn on, even with paperclip trick!
ok
so i disconnect the ECT themostat switch, and put a paper clip to "jump" the connection...
fan will not turn on!!
i checked all fuses in engine bay and inside the car (lower dash) and all fuses are intact!
car is a 00 civic ex y8 motor
FYI the harness im jumping is located on the thermostat housing...
wait whats the paper clip trick, ive never heard of it? i wanna try it cuz my fan has never gone on before and i wannna see if it works
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">wait whats the paper clip trick, ive never heard of it? i wanna try it cuz my fan has never gone on before and i wannna see if it works</TD></TR></TABLE>
Jump the CTS at the upper water neck with a paperclip or length of wire and the fan should turn on (with the car running...duh). It's like pulling codes from the harness at the passenger corner of your EG: it simply shortcuts the signal having to go through that particular "checkpoint" if you will
Is your HVAC fan working? I blew the fuse for that and my car did the same thing. The radiator fan would not come on. It did after the fuse was replcaed. IIRC, it's a 15 amp fuse located in the driver side footwell fusebox.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laserjock »</TD></TR><TR><TD CLASS="quote">Is your HVAC fan working? I blew the fuse for that and my car did the same thing. The radiator fan would not come on. It did after the fuse was replcaed. IIRC, it's a 15 amp fuse located in the driver side footwell fusebox.</TD></TR></TABLE>
well i see a "heater a/c relay" fuse and i checked that and its ok
UPDATE: fan was broken!! wtf
anyways i put in another fan that i tested to work (tested with battery) and with the harness jumped it does nothing
UPDATE AGAIN
******* A!
i was pulling the ECT switch, not the thermostat switch
UPDATE AGAIN
******* A!
spidermancivic
May 5, 2009 09:07 PM
Lo0z3rCIVICBoi
May 8, 2006 06:24 AM
kinvid22
Dec 15, 2003 10:49 PM
