master slave clutch cylinder replace
Old Jun 12, 2005 | 04:51 PM
tbonez's Avatar
Default master slave clutch cylinder replace
I replaced my master and slave cylinder in my civic. I have had some trouble with leaking and have been battling it for a couple of days. I think I have it finally fixed but every time I push in the clutch it squeeks around the slave cylinder. Is this normal or do I have a faulty part or bigger problem? Any advice or thoughts will be greatly appreciated...
Old Jun 12, 2005 | 04:53 PM
e jay one's Avatar
Default Re: master slave clutch cylinder replace (tbonez)
did you grease up where the slave pushes the clutch fork? it could also be the throw out bearing squeeking due to lack of grease.
Old Jun 12, 2005 | 05:27 PM
tbonez's Avatar
The squeek isnt in the pedal so I doubt it is that. The sound comes from the slave cylinder. Is it a major pain to grease the throw out bearing and is it a major issue if I dont do it immediatley?
vlc92189
Nov 6, 2006 08:49 AM
majinx4
Jun 14, 2006 05:46 AM
siregcivic
Oct 16, 2005 07:55 PM
B18PoweredCivic
Sep 24, 2003 10:58 AM
