Buzz sound
Old Jun 12, 2005 | 02:30 PM
Accord95Lxxx's Avatar
Default Buzz sound
i belive i've heard you guys talk about this before. but....usually when the car is cold
i'll take off gently and around 2000 rpms i'll hear a lound BUUZZZZZZZ sounds like
its comin from the exhaust, then it goes away. i never hear it when the motor is warm. from what i've read it has somthing to do with the header, or heat sheild, its done this since we bought the car new in 1995, but were lazy about investigating. i'll fix it if its easy and cheap, but if it requires time and money then its not worth it because otherwise the car is perfect, just annoys me
Old Jun 12, 2005 | 05:42 PM
AccordRacing's Avatar
hard to say .. I was getting a buzz from my PCV valve .. i donno if its normal for it to buzz a little?
Old Jun 12, 2005 | 05:47 PM
mcchau01's Avatar
Default Re: (AccordRacing)
tighten your header bolts. That will probably work for a while, but you may have to get some lockwashers or something. How long has it been happening, and does it go away after you get out of that RPM range? Also, if you take off quickly, is the buzzing sound shorter, or is it constant?
Old Jun 12, 2005 | 05:50 PM
fw190bvi's Avatar
Default Re: (mcchau01)
a combination of the spring loaded bolts and your catalytic converter's heat shield
Old Jun 12, 2005 | 07:11 PM
its been doin it for 10 years...i'll check the sheild and bolts
Old Jun 13, 2005 | 09:29 AM
integ6657's Avatar
Default Re: (Accord95Lxxx)
Most likely...you need to replace the small 6 or 8 inch section of exhaust mid pipe. The dealerships call it the exhaust buzz kit. Most of them are pretty knowlegeble on this subject. The gaskets on the pipe become worn and they rattle or buzz about 2K RPM. There is a service bulletin on it at the dealerships. Pretty common problem with that year model....so I would check there first> Good luck!
Old Jun 13, 2005 | 11:11 AM
solo2slocivic's Avatar
PARTS INFORMATION
Exhaust mid-pipe fastener kit:
P/N 18010-SV4-305, H/C 5027362
(Kit contains two gaskets, four flange bolts,
four springs, and four self-locking nuts.)
Old Jun 13, 2005 | 01:29 PM
thanks alot., .. how much
Old Jan 15, 2007 | 12:14 PM
Homesickelian's Avatar
yeah, I want to raise the subject from the dead instead of starting a new post. Mine has similar symptoms and I'd like to get it dealt with.
This doesn't seem to be much of a DIY eh?
And if I do get it done how much will it cost?
There is no warranty etc? My car has 175,000 so I'm not sure.
My car also makes a buzzing noise at higher rpms in any gear i believe. Around 3500RPM.
I know it's not the transmission since it shifts awesome and never slips etc. I also changed the tranny fluid within 3,000 miles and the fluid is good.
Old Jan 15, 2007 | 12:40 PM
Ross 2.0's Avatar
In a Junkyard near you.
as long as there isn't oo much rust it's definately a good DIY job. Let me know and I can get sme instructions for you. There might be something about it in the FAQ
Old Jan 15, 2007 | 12:54 PM
Default Re: (Ross 4107)
yeah, that would be greatly appreciated. Would I be able to go as far as saying the gasket can reduce performance to like interrupt flow, or is it just making a noise?
I couldn't find any good diagrams but is it the piece between the front end of the exhaust and the catalytic converter, right next to the catalytic converter? Cause if so, it's pretty rusty and ugly.
Modified by Homesickelian at 2:33 PM 1/15/2007
Old Jan 16, 2007 | 07:50 AM
Default Re: (Homesickelian)
come on, anyone else on the exhaust gasket? I can't find any help on a search or FAQs here so.. ?
Old Jan 16, 2007 | 03:40 PM
hondadude's Avatar
S/B 94-041 for your viewing pleasure
Old Jan 16, 2007 | 06:54 PM
Default Re: (hondadude)
Hondadude, you're my hero!!!
Hondadude, do you think this could be a DIY for me? I know that the parts are pretty rusted so it might be difficult.
Is it a matter of busting the rusted bolts and screws replacing them and then replacing the gaskets?
Modified by Homesickelian at 8:04 PM 1/16/2007
MobiusOne
Jun 10, 2012 05:53 AM
95_Civic_4dr
Dec 19, 2009 07:39 PM
5spdcoupe
Jun 5, 2007 03:30 AM
lutz707920
43
Nov 10, 2005 08:22 PM
EK k kay
Aug 19, 2004 12:10 PM
