00 si wire harness help
Old Jun 12, 2005 | 02:22 PM
hialeahzbg's Avatar
Default 00 si wire harness help
well i have a 96 dx coupe and i just changed every harness the car has to a 00 si harness.. everything went well but in teh floor harness when u plug it up 2 the fuel pump theres an extra plug in the si harness that the dx fuel pump dont have....si harness has 3 plugs and the fuel pump has 2.....sop i got the si fuel pump and it also has 2 plugs not 3..wats the extra plug?
Old Jun 12, 2005 | 02:35 PM
DumpedSi's Avatar
Default Re: 00 si wire harness help (hialeahzbg)
theres 3 plugs down there.. One goes into the fuel pump, one goes into some other things that goes into the gast tank( maybe the fuel guage reader) then theres a seperate plug thats connected to some other harness.. I think thats the one you cant find plugged
Old Jun 12, 2005 | 09:54 PM
hialeahzbg's Avatar
yea so now that i cant plug that into anywhere wat do i do? am i gonna have a check engine light?
Old Jun 12, 2005 | 09:58 PM
Kamin's Avatar
why the hell did you put a SI harness in?
Old Jun 12, 2005 | 10:07 PM
hialeahzbg's Avatar
cuz i wanted 2 do a 2000 si wire harness 2 my 96dx. i didnt like the rigged vtec. i wanted everything nice and clean. plus when i put my a/c the car idled really low and it wood turn off...
Old Jun 12, 2005 | 10:22 PM
Kamin's Avatar
Default Re: (hialeahzbg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg &raquo;</TD></TR><TR><TD CLASS="quote">cuz i wanted 2 do a 2000 si wire harness 2 my 96dx. i didnt like the rigged vtec. i wanted everything nice and clean. plus when i put my a/c the car idled really low and it wood turn off...</TD></TR></TABLE>
wow
just wow.
Old Jun 12, 2005 | 10:30 PM
hialeahzbg's Avatar
ok thanx anyone else?
Old Jun 13, 2005 | 01:28 AM
hialeahzbg's Avatar
wat happens if it aint plugged in?check engine light?
Old Jun 13, 2005 | 04:02 AM
EE_Chris's Avatar
Buy a Helms and check to see what it is you're missing.
You've probably created more problems than you solved by going this route. What ECU are you using - a 2000 Si? The 2000 Si looks for an FTP sensor which your Dx may not have (this may be the plug that you can't seem to find something to plug it into) and there isn't a 'fix' for this code either (usually Code 90).
Old Jun 13, 2005 | 10:48 AM
hialeahzbg's Avatar
damn and yea im usin stock si ecu.....how bout it i put a jumper with a chipped p28 will it still show a check engine light....and wat does that ftp sensor do?
Old Jun 13, 2005 | 11:50 AM
EE_Chris's Avatar
Do you have emissions where you live? If yes, since you're OBD2, when you go into the station to get checked, they hook up a scanner to the ECU - OBD1 ECU's can't talk to that scanner so you instantly fail.
FTP stands for Fuel Tank Pressure sensor and is used in the detection of leaks in the EVAP equipment.
Yes you can run a jumper harness + P28.
Old Jun 13, 2005 | 12:14 PM
hialeahzbg's Avatar
i live here in miami and no emissions here thank god.....so if i run a chipped p28 ill be fine? the plug wont make a difference on how the car runs?
Old Jun 13, 2005 | 12:29 PM
EE_Chris's Avatar
What plug? The plug that 'might' be related to the FTP? Since the FTP made its introduction in 1996 for OBD2, no, you won't have to worry about it.
aug
Jan 8, 2008 10:39 AM
VPR-01CTR
Jan 27, 2007 01:42 PM
elmalouno
Apr 26, 2004 02:35 PM
H22AEG2
Oct 17, 2003 08:36 PM
