misfire
installed a new cap and rotor and now everytime it starts going into high rpm's it'll just make a pop pop pop sound. what could it be? no other changes were made to my car besides the new cap and rotor
a pop pop?, can you feel a drain in power, like it is running on less than 4 cylinders?
I would go with replacing other ignition components, plugs, wires, maybe even the ignitor if that has gone bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">I'll bet all the money I own that your plug wires are either 90 degrees off or in the wrong order
.</TD></TR></TABLE>
what do u mean 90 degrees off?
.</TD></TR></TABLE>what do u mean 90 degrees off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx »</TD></TR><TR><TD CLASS="quote">i don't know what he means by that either, but i would think if they are in the wrong order it wouldn't run fine in the lower rpms either. check your wires and plugs though</TD></TR></TABLE>
its not the wires or plugs, they are in the correct order and plugs are fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dreams »</TD></TR><TR><TD CLASS="quote">make sure u put the screw back into the rotor and that there is no debre in side the cap like oil or water</TD></TR></TABLE>
yup, tightened the rotor down and opened up the cap and didnt find anything in it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dreams »</TD></TR><TR><TD CLASS="quote">maybe u got a bad rotor or cap does any of the points look burnt</TD></TR></TABLE>
nope, they were all in wrapping and i checked it b4 i installed it
crxaddikt
11
Jul 25, 2013 11:57 AM
Paprika
34
Dec 28, 2005 03:52 PM
JoshuaVTEC
11
Jul 24, 2004 04:45 PM
