Dented Header Hurt Performance??
Old Jun 12, 2005 | 01:15 PM
{Powered by VIII}'s Avatar
Default Dented Header Hurt Performance??
i wanted to see what you guys think about this pretty good size dent i have in my comptech long tube header. i bought it like this so it wasn't my fault, but i want to see if it's big enough to where it's gonna hurt the performance and should do something about and if it is what can i do??
Thanks. Alex.
Old Jun 12, 2005 | 01:22 PM
weak_tec's Avatar
Default Re: Dented Header Hurt Performance?? ({Powered by R})
man that sucks you can cut that shiet out and weld a thick piece of metal on it, thats what my guy did, but he works at a machine shop. i wouldnt recommend. btw how much did u get that for anyway?
Old Jun 12, 2005 | 02:52 PM
TsukubaDreams's Avatar
OUCH!!! Yea thats gonna hurt your performance because it will cause turbulance through that tube. You might be able to heat it up with a torch, take a broom handel and shove it in there to straighten it out a little. Think of a header like a insturment, like a tuba or flute or something like that. Its not just the size of the tube that helps flow, but it tunes it so its not turbulent goint through there which creats a nice flow. You have one fucked up tuba
Old Jun 12, 2005 | 02:57 PM
riceball777's Avatar
ouch
of course it will hurt performance
i seem people cut the peice out and weld in another piece of metal to fix it
Old Jun 12, 2005 | 03:26 PM
if i cut out the dent and weld in a new piece, isn't going to weaken it in that area though??
Old Jun 12, 2005 | 03:32 PM
SD1222's Avatar
like TsukubaDreams said u might wanna heat it up and try to see if u can push that piece out. It doesnt look too big of a dent.
Old Jun 12, 2005 | 06:42 PM
Suck my DX's Avatar
Default Re: Dented Header Hurt Performance?? (jdm_spoonEG)
not as bad as mine...mine has dents twice as deep as that on both tubes...and hell yeah after it happened i could tell the difference...
Old Jun 12, 2005 | 08:12 PM
EG6R's Avatar
Ive a DC 4-1 with worse dents than that. I cut them up and welded . Dented them again, and welded another piece again. I couldnt tell the difference honestly, maybe because my butt dyno isnt as accurate as others.
I remember my first header, i crushed them so bad the two pipes were flat as paper. Car could hardly accelerate but i had to drive back home for another 20miles.
sjg88
May 31, 2017 07:11 AM
{Powered by VIII}
Jun 15, 2005 09:07 AM
eg6hatch
15
Nov 26, 2004 09:12 AM
ice11honda
11
Sep 21, 2004 02:56 AM
neo1z
Apr 8, 2004 09:06 PM
