simple question... JDM ITR (OEM) header look like this?
Old Jun 12, 2005 | 11:23 AM
jdmsiR20's Avatar
Default simple question... JDM ITR (OEM) header look like this?
simple question... got the diagram for USDM header(s)... anybody have the JDM one?
basically, trying to bolt on a JDM (OEM) ITR header on a 94-99gsr... wont work eh?
thx
Old Jun 12, 2005 | 11:25 AM
B18ls*RAYON's Avatar
Default Re: simple question... JDM ITR (OEM) header look like this? (jdmsiR20)
ugh, sure...
Old Jun 12, 2005 | 11:49 AM
hutchenc's Avatar
I just did this on my '94 about a month ago. It'll work just fine but you'll have to get a different cat since the JDM header is longer than a stock '94-'99 manifold. I'd contact SMSP for a high flow cat and he'll get you one that'll drop right in.
The stabilizer bracket on the JDM ITR one won't line up with the stock '94-'99 exhaust manifold bracket though...you'd have to buy one for the JDM header. Inlinefour has these at http://inlinefour.com/25incolgas.html
This bracket isn't 100% necessary though. It's your call.
Old Jun 12, 2005 | 02:14 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: simple question... JDM ITR (hutchenc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hutchenc &raquo;</TD></TR><TR><TD CLASS="quote">I just did this on my '94 about a month ago. It'll work just fine but you'll have to get a different cat since the JDM header is longer than a stock '94-'99 manifold. I'd contact SMSP for a high flow cat and he'll get you one that'll drop right in.
The bracket that you mention is for the JDM 4-1 ITR header. The 4-2-1 header uses the same bracket as the USDM header.
My 98 spec Mugen 4-2-1 header required the JDM 4-1 bracket.
Old Jun 12, 2005 | 02:20 PM
jdmsiR20's Avatar
Default Re: simple question... JDM ITR (Dogginator)
what about your 02 sensor on the cat.... did u extend the wires or just use the one on the header?
ok i answered all my questions...
thanks all (03 member!)
Old Jun 12, 2005 | 03:22 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: simple question... JDM ITR (jdmsiR20)
I used the O2 sensor port in the header and coupled it with a JDM ITR catalytic converter. I had to change the bung for the secondary O2 sensor on the converter, as the JDM version was a 2-wire model.
Old Jun 12, 2005 | 08:33 PM
hutchenc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">what about your 02 sensor on the cat.... did u extend the wires or just use the one on the header?</TD></TR></TABLE>
This depends on whether you have an OBD1 or OBD2 car. Mine is OBD1 so I only had to deal with one O2 sensor. Basically, because the header is longer than the stock manifold, the O2 sensor for the JDM ITR header just goes into the bung in the collector (that is...the collector bung is in the place where the stock cat bung used to be). No extending of wires necessary...which is why I stuck with OEM Honda parts! I didn't need to mount one after the cat since my car is OBD1.
Hopefully that makes sense.
On a side note...the addition of the header and hi flow cat makes my car sound really ******' loud when I get on it. Honestly, I'm not all that happy with the noise level. I think I'll end up replacing my muffler sooner than later. Just be prepared.
Old Jun 12, 2005 | 10:09 PM
jdmsiR20's Avatar
yuppP had the same idea... just gonna have a second o2 sensor in the cat not hooked up...
off to the muffler shop for me, cut and reweld...
in the meantime, loud as fukk!
deary09
Sep 4, 2011 12:30 AM
type-GGSR
Feb 19, 2008 10:14 PM
Civichatch2k
Oct 14, 2004 07:05 AM
Tommy_Gunns
Mar 10, 2002 07:00 AM
SMSP
Feb 13, 2002 11:36 PM
