Leaky Trunk
Old Jun 12, 2005 | 06:58 AM
90AccordTx's Avatar
Default Leaky Trunk
Ok my 90 Accord LX has a major trunk leakage i guess from bad weather stripping, is their a better way to fix this problem other then replacing the whole stripping??
Old Jun 12, 2005 | 08:37 AM
deserthonda's Avatar
Default Re: Leaky Trunk (90AccordTx)
replace the tail lense gaskets,
Old Jun 12, 2005 | 11:32 AM
Accord95Lxxx's Avatar
either that or he needs to replace the rubber surrounding the trunk opening
Old Jun 12, 2005 | 01:35 PM
Chiovnidca's Avatar
Default Re: (Accord95Lxxx)
Could be leaking somewhere else too.
Old Jun 12, 2005 | 02:33 PM
ya know once i thought it had a leak in my legends trunk, but it turned out that i had a jug of water in there i forgot about and it got pucturedand leaked water and it sat for months, molding, finally i realized it was the jug
Old Jun 12, 2005 | 04:24 PM
jb.'s Avatar
jb.
Default Re: Leaky Trunk (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">replace the tail lense gaskets, </TD></TR></TABLE>
i had this same problem in a previous oldsmobile
Old Jun 13, 2005 | 09:04 PM
90AccordTx's Avatar
is it easy to replace the rubber strippings
Old Jun 13, 2005 | 09:06 PM
90accorddx's Avatar
Default Re: (90AccordTx)
probably the taillights when i open the trunk of my car the passenger side tail light dumps water out of it
Old Jun 13, 2005 | 10:32 PM
hawkimport's Avatar
Default Re: (90accorddx)
do you have a wing installed on your trunk? if not then I would say its the weather strip
Old Jun 14, 2005 | 08:09 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90AccordTx &raquo;</TD></TR><TR><TD CLASS="quote">... is their a better way to fix this problem other then replacing the whole stripping??</TD></TR></TABLE>Yeah, first figure out if that's really what's leaking. Crawl in with a flashlight & have a friend douse the car with a hose. Don't bother with the weatherstripping if it's coming in thru the taillight. Or the sunroof drain hoses. Or that rust hole over there...
Old Jun 14, 2005 | 06:41 PM
JIMBLAKE advice is the correct idea diagnose before replacing but from experience i would suggest that it is the tail lite gaskets i have replaced a **** load of them they get old, they crack and let water in , remove tail lite assembly and install new gaskets they cost around $ 5-6 dollars each and when replacing put a good beed of silicone in the body side of it
Old Jun 16, 2005 | 09:53 PM
e2005man's Avatar
knowing the 90-93 accords......do you have any rust around the rear wheels?
On my old accord water would come in through the rust when i drove in the rain.
Old Jun 23, 2005 | 06:43 PM
what was the fix??????
rein1116
Jun 6, 2007 07:35 PM
tytyguy
May 9, 2006 04:10 AM
TurboGS-R
Apr 2, 2006 10:32 PM
95GS-R
Dec 28, 2003 03:11 PM
Kryptonite
Aug 26, 2003 09:57 PM
