Help me i think i blew my motor!!
Old Jun 11, 2005 | 03:46 PM
b18c5 EG's Avatar
Default Help me i think i blew my motor!!
ok so i installed buddy club cams and i finally got the timing straight at a shop today....i was driving around downshifted into 2nd and BAMMM!! i heard a pop...got it towed home took the spark plugs out and it was bend w/metal pieces on it...i think i blew my piston in cylinder #4....i am going to be rebuilding it and i thought hell while the motor is apart i should replace everything...i want to do type r pistons...can somebody give me a parts list on what else i should get replaced....also is it worth getting the .20 oversized pistons?? thanks
Old Jun 11, 2005 | 03:57 PM
Kendall's Avatar
Don't count your chickens before they hatch. It's possible that your head and/or sleeves are quite fucked up. Get the motor apart before you start making any decisions.
We're you running on a stock valvetrain?
Old Jun 11, 2005 | 04:02 PM
b18c5 EG's Avatar
yeah i was but the buddy clubs are fine with stock valvetrain....i never take it past 8k so it should have been fine...i dont understand because its been on the road for 2 days and i didnt even beat it
Old Jun 11, 2005 | 04:05 PM
Kendall's Avatar
Is it a B16? If so then the stock B16 valvetrain really isn't sufficient. I was under the impression that at least ITR valvesprings would be necessary. From the description you gave it sounds like it dropped a valve.
Old Jun 11, 2005 | 04:23 PM
Yambor's Avatar
Default Re: (Kendall)
emm what year b16? Maybe you have the early LMA's with a smaller pad and the tit on the mid rocker slipped off the pad and caused your valvetrain to bind at full vtec lift and bam...piston - valve
Old Jun 11, 2005 | 04:35 PM
b18c5 EG's Avatar
its a b16a3.....it came with my 1994 honda del sol....im gonna check compression tomorrow...this sucks i just got it on the road yesterday.....i just asked for a parts list just incase...or would it be cheaper to buy a short block?
Old Jun 11, 2005 | 08:52 PM
Kendall's Avatar
Remember that you're also running the possibility of having fucked up the head as well. It may be in your best interest to buy a longblock if the block you have isn't salvagable.
Old Jun 11, 2005 | 10:33 PM
b19coupe's Avatar
Default Re: Help me i think i blew my motor!! (94_Del Sol)
Last time I dropped a valve my sleeves were cracked
Old Jun 11, 2005 | 11:53 PM
b18c5 EG's Avatar
great....im taking it apart tomorrow so ill give u guys some pics!
slixterN
27
Aug 6, 2013 04:32 PM
paulzy
Jan 26, 2009 07:31 PM
jdmcivic10
13
Nov 26, 2008 08:51 AM
pchan
Nov 24, 2006 06:33 PM
BigAnold
Sep 1, 2005 09:00 AM
