98' Civic EX D16Y8 OBD2B Ecu Questions
Okay, for a 1998' Civic EX OBD2A that has the stock ecu, (not sure what code is) but with that setup, to run a P28 what needs to be done?
Buy a Harness say from Boomslang OBD2A to OBD1 and than a P28 ECU, would that be it? or is there some other things that need to be done? Thanks guys.
PS. Searched, couldn't come up w/ my exact question's answer.
Modified by brianmgroverpeterson at 7:52 PM 6/11/2005
You also should set timing to D16z6 specs
Otherwise pretty much plug and play. There are some differences in IAT readings but nothing major
FRKWOO
Nov 4, 2008 07:39 PM
