Fuel Pump not priming - Main Relay?
For reference: The car is a bone stock 92 CX hatch, 93k miles
Sometimes when i turn the key, the fuel pump wont prime, it seems like its more common when it's hot out. The car will start, then just cut right back off, is this a typical symptom of a bad main relay? Also, it seems to be more common when im low on gas. Well, it did it a lot yesterday and after i got gas it hasnt really done it, i think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rentacop »</TD></TR><TR><TD CLASS="quote">For reference: The car is a bone stock 92 CX hatch, 93k miles
Sometimes when i turn the key, the fuel pump wont prime, it seems like its more common when it's hot out. The car will start, then just cut right back off, is this a typical symptom of a bad main relay? Also, it seems to be more common when im low on gas. Well, it did it a lot yesterday and after i got gas it hasnt really done it, i think.</TD></TR></TABLE>
Have you tested the fuel relay yet? To see if it's working or not?
Could be. Honda main relays are dula relays. The first relay powers up the computer and supplies power for the second relay. Once the computer is powered up, it will ground the second relay, which supplies power to the fuel pump. Main relays usually goes out when u leave your car under the sun when its real hot out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet »</TD></TR><TR><TD CLASS="quote">Have you tested the fuel relay yet? To see if it's working or not? </TD></TR></TABLE>Does the fuel pump have its own relay? IF so then i suppose i'd replace that first before messing with the main relay
I thought about that, but its purely electrical, because once the car actually starts nothing else happens, as far as power loss or stuttering, so it must be a relay. Thanks though.
And thanks Relic for the link.
1hotintegra
Aug 14, 2004 11:10 AM
