ITR trailing arm works on 00 civic?
Old Jun 11, 2005 | 09:19 AM
yh23's Avatar
Default ITR trailing arm works on 00 civic?
Doing 5lug swap, im switching just the the hubs, but was curious if the trailing arms are the same? they look very similar.
Would the ITR trailing arm work on my 00' Si?
thanks!
Old Jun 11, 2005 | 10:03 AM
EricUSC's Avatar
Default Re: ITR trailing arm works on 00 civic? (yh23)
The ITR trailing arms would work on all 92-00 Civics. I have them on my '97 Civic, and I have seen them on other Civics.
Old Jun 11, 2005 | 10:07 AM
yh23's Avatar
Default Re: ITR trailing arm works on 00 civic? (EricUSC)
Is the ITR trailing arm better?
Should I switch out the whole trailing arm or just the hubs?
Old Jun 11, 2005 | 10:11 AM
DumpedSi's Avatar
I'd swap them directly over
Old Jun 11, 2005 | 10:18 AM
EricUSC's Avatar
Default Re: ITR trailing arm works on 00 civic? (Slammed Si)
Swap the whole thing over. It's takes a lot of time to swap all of the parts from the ITR arm to the Civic arm. The only reason I would do it is if the ITR arms are damaged. I don't think that the ITR arms are "better".
Old Jun 11, 2005 | 11:43 AM
buy my boosted ek's Avatar
i have ITR trailing arms on my 00 hatch. just swap it over. it's easier than swapping the hubs.
Old Jun 11, 2005 | 12:13 PM
Default Re: ITR trailing arm works on 00 civic? (buy my boosted ek)
i just got your IM. i cant IM you back because i'm still a trail user. but to answer your question, the ITR e-brake lines are a little longer but it'll still work and bolt on. it's straight forward. just look at your old lines, take them out, put in the ITRs. good luck.
Old Jun 11, 2005 | 01:37 PM
yh23's Avatar
didnt get ITR e-brake cables with my swap, can I use my stock 00' Si e-brake cables?
Old Jun 11, 2005 | 01:55 PM
Unjockable's Avatar
New User
SI e-brake cables would work even better.
Old Jun 11, 2005 | 02:30 PM
yh23's Avatar
Default Re: ITR trailing arm works on 00 civic? (Unjockable)
ok, cool.
how do i remove my stock si ebrake lines? since, i cant pull it through the hole on the trailing arm. the bracket on the ebrake line is too big to fit through the hole.
so what to do??
any help is greatly appreciated!
thanks h-t members!
Old Jun 11, 2005 | 03:10 PM
KCoupe's Avatar
just swap the whole thing over.!!!
for another 5 lug conversion
CroSi
Jun 14, 2018 04:35 PM
zacTYPE-R
Aug 1, 2010 09:25 AM
1337 Si
14
Feb 13, 2006 07:30 AM
an2ny888
Oct 24, 2003 08:13 AM
