buying an EG...common problems to look for
rust in the corner panel from water sitting in between the plastic splash gaurd and the quarter panel. The portion that rusts is usually where that style line is.
if it's an Si, sunroof leaks (easy fix)
Water leaks all over the floor are common.
water leaks in the back
A lot of these problems can be fixed i would say the major thing u wanna check for is if the quarter panel was worked on because if it was a crappy DIY cover-up then it's still corroding in there and it's gonna bite you in the *** crack and tear your nuts off until your ********* are non exhistant.
hbracer93
41
Apr 6, 2022 05:04 AM
mohater
15
Jan 22, 2012 05:33 PM
92EGMINIME
Apr 8, 2009 12:34 AM
Mazmay
15
Jun 14, 2003 10:01 PM
