Cartech FMU wrt wideband 02 values..
Old Feb 10, 2002 | 01:54 PM
Giuseppe's Avatar
Default Cartech FMU wrt wideband 02 values..
ive seen a few dyno plots with guys either running
a vortech FMU, which is unadjustable
or hondata with has many ajdustable parameters..
what kind of AF values should i tune for
when using the Cartech unit..???
any info appreciated...!
TIA
Old Feb 11, 2002 | 09:03 AM
Giuseppe's Avatar
Default Re: Cartech FMU wrt wideband 02 values.. (Giuseppe)
come on guys any cartech dyno plots...
id really like to see a few AF ratio readings..!!
TIA
Old Feb 11, 2002 | 11:40 AM
Xerxes's Avatar
New User
sorry, i don't know anything about the cartech (other than that it's a bitch to tune ) but you should shoot for around 11.5:1 to 12:1 a/f ratio for a safe mixture... 12.5:1 for max power (but higher risk!)
-Xerxes
Old Feb 11, 2002 | 12:11 PM
Giuseppe's Avatar
Default Re: Cartech FMU wrt wideband 02 values.. (Xerxes)
please explain..
11.5 is a leaner mixture compared to 12.5
problem is i cant get a 'flat' AF ratio and have to tune accordingly,
and get a nice 'slope' to get close to 12.5 as possible...thanks for the input. anybody else..??
[Modified by Giuseppe, 9:12 PM 2/11/2002]
Old Feb 11, 2002 | 12:14 PM
dbman96's Avatar
New User
No, 11.5 is definitely richer than 12.5
A/F ratio is air divided by fuel... lower number = more fuel, less air, = richer.
Your car cruises around 14.7:1 for ideal efficiency, but typically 12.5 is the target for max power; tune to 11.5 or 12 for some safety margin.
Can you explain what you mean by "can't get a flat AF ratio?"
[Modified by dbman96, 1:15 PM 2/11/2002]
Old Feb 11, 2002 | 12:25 PM
Giuseppe's Avatar
Default Re: Cartech FMU wrt wideband 02 values.. (dbman96)
sorry my bad on that..11.5 is richer that 12.5
brain freeze..
'horizontal ideal' -----------------
i guess guys with hondata have soo much tuning ability
they can get a real steady level AF ratio...
Vortech FMU u cant adjust, (at all)
cartech (minimal adjustment) to raise Xamount per psi boost etc etc..
green97coupe
Jun 9, 2010 11:50 AM
redlseg
May 16, 2005 05:34 AM
kovert
Aug 17, 2004 09:58 AM
SOUTHCREX
Aug 17, 2002 02:47 PM
B20-T
Jul 31, 2002 12:24 PM
