Need some input nitrous people !!!
Old Jun 10, 2005 | 08:43 PM
redcrx187's Avatar
Default Need some input nitrous people !!!
I currently would like to build a nitrous set up> i currently have a ls/vtec that i would like to build the block for nitrous. I was wondering if anybody here has done this before and what kind of internals are suggested i know sleeves are manditory but what pistons ,rods... and what compression i would like to put about a 200 shot on this set up if not more so all help and input would be great and it will be a direct port set up and i would also like to use a step n2o set up like 50shot out of the hole 100shot second 150 3rd and 200 or more 4th thanks
Old Jun 10, 2005 | 09:07 PM
evilhatch2.0's Avatar
Default Re: Need some input nitrous people !!! (redcrx187)
just go about building a regular turbo block
Old Jun 10, 2005 | 09:31 PM
redcrx187's Avatar
so what compression ? and who sells a step n2o set up?
Old Jun 10, 2005 | 10:55 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: (redcrx187)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redcrx187 &raquo;</TD></TR><TR><TD CLASS="quote">I currently would like to build a nitrous set up&gt; i currently have a ls/vtec that i would like to build the block for nitrous. I was wondering if anybody here has done this before and what kind of internals are suggested i know sleeves are manditory but what pistons ,rods... and what compression i would like to put about a 200 shot on this set up if not more so all help and input would be great and it will be a direct port set up and i would also like to use a step n2o set up like 50shot out of the hole 100shot second 150 3rd and 200 or more 4th thanks</TD></TR></TABLE>
Well from what youre describing...youll be running a 500 shot...which might be a little much for your setup . When most people talk about their steps they say what each one is adding. So if you spray a 50 out of the hole then the second step was 100...youd have a 150 shot. It compounds. Thats the way all the guys around here say it anyway. Good luck on your build
Old Jun 12, 2005 | 07:47 PM
redcrx187's Avatar
lol yeah i could see how it would look that way but i think you know what i mean
Old Jun 17, 2005 | 10:50 PM
OMG B16's Avatar
This was my origional plan untill i decided to go turbo ;-).
B16 Block:
Darton block 84mm
Cp 11:1 pistons
Eagle Rods
B16 Crank
GSR Tranny w/LSD
B16 Head:
Portflow valvetrain
GSR cams
PNP
3 angle valve job
N2o:
Direct port 100 shot. 1-2-3-4 Gear
Single fogger 75 shot DRY. 3-4 Gear
A friend has a similar set-up in a 98 coupe that went 11.5 @ 120
Old Jun 18, 2005 | 03:06 AM
JSpin's Avatar
Default Re: (Sick00SiCoupe)
is this going to be a street car or a race car?
check out the forum@ phasechangeracing.com .......it's only a week or so old, but i garuntee you'll get the information you're looking for, probably more than you want
Old Jun 18, 2005 | 12:24 PM
snowseeker's Avatar
Default Re: (JSpin)
So combined 175 on 3rd and 4th? or just the 75? i would say it could take the 175. The rods will most likely go before anything else.
I am going to run 100 direct port with 12.5:1
Old Jun 18, 2005 | 05:17 PM
redcrx187's Avatar
well a 50 in 1 then another 50 in 2=100 then another 50 in 3=150 then either another 50 or 75 in 4 =200 or 225 thats the plan anyway
Old Jun 18, 2005 | 05:39 PM
snowseeker's Avatar
Make sure you video tape the first run at the track.
Old Jun 19, 2005 | 07:51 PM
redcrx187's Avatar
why you dont think it will last?
Old Jun 19, 2005 | 08:06 PM
snowseeker's Avatar
I don't know, seems like alot. It might hold together at 225 but I doubt it. Video tape it anyhow, I wanna see what the car will do with 200+.
I would say some pewter rods and 10.5:1 - 11:1 CP pistons on the stock crank should hold. Some good sleeves of coarse and some good valves.
Old Jun 19, 2005 | 08:49 PM
884drb16's Avatar
Default Re: (snowseeker)
this is my homies nitrous set up he had on his teg daily driven http://www.cardomain.com/memberpage/672307 read everything... it was a b20 vtec je 8:1 compression pistons it made 353whp & 300 fpt
Old Jun 20, 2005 | 05:45 AM
cubish's Avatar
https://honda-tech.com/zerothread?id=1215880
my car is making well over 400hp. it went 11.1@125 with around 350-370
its on a dual stage set up now. around 180-200 out the whole and another 80-90 dry up top
Old Jun 20, 2005 | 08:01 AM
snowseeker's Avatar
Default Re: Need some input nitrous people !!! (cubish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cubish &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1215880
its on a dual stage set up now. around 180-200 out the whole and another 80-90 dry up top</TD></TR></TABLE>
I hope it would make over 400 with a 370 shot.
Old Jun 20, 2005 | 08:39 AM
JSpin's Avatar
i would imagine cubish is spraying about as much nitrous as that motor can physically intake, or getting close at least. that amount of nitrous is surely displacing the amount of air the motor can naturally ingest.
never the less, thats good stuff right dur
Old Jun 20, 2005 | 12:09 PM
cubish's Avatar
not a 370 shot...370 horse
Old Jun 20, 2005 | 02:24 PM
snowseeker's Avatar
Default Re: (cubish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cubish &raquo;</TD></TR><TR><TD CLASS="quote">not a 370 shot...370 horse</TD></TR></TABLE>
Ahh, I see now.
Old Jun 20, 2005 | 08:20 PM
redcrx187's Avatar
Default Re: (JSpin)
Cubish........looks good my car is a crx so with me i should be around 2100-2200 and i heard i should run the 24" slicks instead of 22" and you just proved that im also running a y1 trns in my rex thanks for your input and i am assuming your block is sleeved i just didnt see that i was sleeved in your parts list . and what kinda sleeves are u running once again thanks for ur input.
Old Jun 20, 2005 | 08:25 PM
redcrx187's Avatar
Snowseeker i sent you a pm about yor tb's let me know thanks
Old Jun 20, 2005 | 08:35 PM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redcrx187 &raquo;</TD></TR><TR><TD CLASS="quote">Snowseeker i sent you a pm about yor tb's let me know thanks</TD></TR></TABLE>
Old Jun 21, 2005 | 04:14 PM
cubish's Avatar
Default Re: Need some input nitrous people !!! (snowseeker)
yeah with the 11.1@125 it was only on like a 160-170. never got to run it with both stages...was close to 300 with both stages. i dont think the motor can take anymore. went through a few head gaskets, but it could also be my compression is close to 14:1.
about the sleeves my current block has darton mid's 84mm. my old set up was stock sleeves with just pistons and rods on a 130 shot and went 11.5@119 on 22" slicks, im now running 24"s
Old Aug 22, 2005 | 03:18 PM
Shaun's Avatar
cubish
dominicanito49
Aug 22, 2006 09:21 PM
blown up
Jan 29, 2006 08:22 AM
dabig1
11
Aug 13, 2004 01:59 PM
Modifiedinteg
Nov 27, 2003 05:27 PM
