kteller 2.5
Old Jun 10, 2005 | 12:35 PM
blkitr's Avatar
Default kteller 2.5
So i just ordered my kteller 2.5" catback with the Slip fit system, and a Omnipower Test pipe.. I can't Get the damned Ever so easy slip fit pipes to slip in.. It seems they aren't wide enough anybody had any trouble installing theres??
Old Jun 10, 2005 | 01:06 PM
Chris F's Avatar
Default Re: kteller 2.5 (blkitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkitr &raquo;</TD></TR><TR><TD CLASS="quote">So i just ordered my kteller 2.5" catback with the Slip fit system, and a Omnipower Test pipe.. I can't Get the damned Ever so easy slip fit pipes to slip in.. It seems they aren't wide enough anybody had any trouble installing theres?? </TD></TR></TABLE>
Is the slip-fit made to hold a 2.5" ID pipe? does it look close?
Any chance the pipe or fitting is slightly out of round?
My first thought would be to grind/dremel the fitting to sharpen the edge. Grind the inside edge of the fitting, grind the outside edge of the pipe that goes into it. Follow that up with a BFH.
Exhaust shops sell various slip-fittings, Autozone/Pep boys too. good luck.
Good luck.
-Chris
Old Jun 10, 2005 | 01:09 PM
blkitr's Avatar
The pieces appear to be slightly larger on the ends that should slip but not quite large enough. Just wondering if anybody else had this problem before i take the ol dremel of death to her. lol..
Old Jun 10, 2005 | 09:09 PM
uNF$@#!'s Avatar
Default Re: (blkitr)
try lubing it up
Old Jun 11, 2005 | 07:04 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkitr &raquo;</TD></TR><TR><TD CLASS="quote">The pieces appear to be slightly larger on the ends that should slip but not quite large enough. Just wondering if anybody else had this problem before i take the ol dremel of death to her. lol.. </TD></TR></TABLE>
They sell exhaust pipe expanders at Autozone. I just saw one. You might call around, or take it to an exhaust shop to see if they can expand it for $10.
Not sure if it works, worth a shot.
Old Jun 11, 2005 | 07:42 AM
blkitr's Avatar
Default Re: (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">try lubing it up </TD></TR></TABLE>
KY warming Jelly?? lol.. I'm just gonna go with the dremel method tomorrow morning.. Thanks guys..
Old Jun 11, 2005 | 06:59 PM
blkitr's Avatar
a little bit of dremel love and she slipped in like butter.. just can't wait to get her hung..
Old Jun 11, 2005 | 09:40 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkitr &raquo;</TD></TR><TR><TD CLASS="quote">a little bit of dremel love and she slipped in like butter.. just can't wait to get her hung.. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkitr &raquo;</TD></TR><TR><TD CLASS="quote">KY warming Jelly?? lol.. I'm just gonna go with the dremel method tomorrow morning.. Thanks guys.. </TD></TR></TABLE>
That's a pretty rough way to treat a virgin, but whatever works.
Old Jun 12, 2005 | 09:39 PM
.water's Avatar
what did you do with the dremel?? grind the edge?
Old Jun 13, 2005 | 08:36 AM
blkitr's Avatar
^ yyeah just did a little grinding on the inside edge of the accepting end of the pipes.. Didn't have to take off barely anything
Old Jun 13, 2005 | 10:34 AM
bdb's Avatar
bdb
KTeller makes good stuff.
Old Jun 13, 2005 | 11:18 AM
Educator's Avatar
What are you using to seal the pipes together? Clamps? Also what muffler are you using with it? Magnaflow?
Thanks
Old Jun 13, 2005 | 02:10 PM
ildknyli's Avatar
Default Re: (Educator)
Post pics
Old Jun 13, 2005 | 06:14 PM
blkitr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Educator &raquo;</TD></TR><TR><TD CLASS="quote">What are you using to seal the pipes together? Clamps? Also what muffler are you using with it? Magnaflow?
Thanks</TD></TR></TABLE>
I'm using the clamps supplied in the Kteller bolt up cat-back piping kit.. And yup i'm using a magnaflow universal 2.5in and out oval muffler..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ildknyli &raquo;</TD></TR><TR><TD CLASS="quote">Post pics </TD></TR></TABLE>
I'll try and get up some pics when i get home tonight or tomorrow morning before work.
Old Jun 13, 2005 | 10:21 PM
dfoxengr's Avatar
you could have heated the outer section up with a propane torch and it shouldve slid over like cake.
Old Jun 15, 2005 | 07:50 AM
Educator's Avatar
What cat are you using?
Old Jun 15, 2005 | 08:34 AM
blkitr's Avatar
^ no cat. Just a OmniPower 2.5in Test Pipe
Old Jun 16, 2005 | 10:18 AM
Educator's Avatar
Nice. Got pics? I'm considering going with this set up. I need to get a hi flow, but quiet exhaust. My exhaust is way too buzzy.
Old Jun 16, 2005 | 10:41 AM
blkitr's Avatar
no pics yet i've been busy with work. Tomorrow is my day off though so i should be bolting it up and i'll grab some pics then.. I don't know how quiet it's gonna be though i've heard it is pretty loud without the optional resonator option.. It's pretty much straight pipe from thejdm 2.5" header back to high flow magnaflow muffler.. i'm not expecting it to be any kind of quiet..
lsvtec101
10
Nov 4, 2005 02:35 AM
Del Slow
Apr 18, 2005 01:51 AM
Integra21
Apr 5, 2005 04:52 AM
Teg4e
May 29, 2002 10:41 AM
