turbo integra died on me today
Old Jun 10, 2005 | 11:45 AM
sp00led's Avatar
Default turbo integra died on me today
I was sitting at a light on my lunch break when all of a sudden car starting running like ****. It droped to damn near stalling idles and as soon as i hit the gas it stalled out and white smoke started coming from my hood for a few secs. I pushed it out of traffic and called a tow truck in fear that it jumped timing or even worse. Poped the hood and the smoke was gone and couldn't smell anything. I looked there were no fluids leaking, it had oil, wasn't over heated (oil pressure/oil,water temp). Once i got it to the shop we checked for the obvious it had fuel pressure, it was sparking.
Now im stuck back at work and praying its nothin major. Though I fear the worst.
Old Jun 10, 2005 | 12:00 PM
POWERINTEGRA's Avatar
Default Re: turbo integra died on me today (redeyz)
were you flooring on the gas before the light?
sounds like a piston fried...
Do a comp. test and leak down test you might have a bad piston. Pull head off
Old Jun 10, 2005 | 12:02 PM
sp00led's Avatar
Default Re: turbo integra died on me today (POWERINTEGRA)
I left work drove 5miles got some food and turned off the car. started it back up drove about 1 mile down the road got caught at a light and was sitting there idling around 1k when it happend
Old Jun 10, 2005 | 02:06 PM
Finger Lickin' good's Avatar
looking at your sig, nice set-up. I agree, first comp test, that will give a good start point.
Old Jun 10, 2005 | 05:28 PM
s-tech's Avatar
banned
did you sleeve and replace with turbo pistons, sorry didn't see it on the list, if you didn't I also agree with the piston (wring)...
Old Jun 10, 2005 | 09:18 PM
1158's Avatar
I don't have an answer for you, but just wanted to suggest posting this in the FI forum. You would probably get more suggestions there.
Old Jun 10, 2005 | 09:36 PM
Lauj87's Avatar
did your car make any noises...like rattlin..and do you have an oil pressure gauge?..if you do what dose it read?......somethin like this happen to my bros civic..and his pressure gauge shout to like 100 psi..found out later he had crushed rod bearings....it damaged his crankshaft too soo he went and got a new motor. well good luck!
Old Jun 11, 2005 | 09:56 AM
sp00led's Avatar
My tuner/mechanic just called telling me he has it running. Ignitor in the Distributor went out. I guess that would explain the white smoke once i poped the hood. Sux i didn't get a good smell of the smoke or surley i would have known it was electrical ive smelled plenty of amps go up in smoke. WOOOHOO and i thought i was gonna have to spend 3G's on a fully built/sleeved block looks like i got a little bit longer. FYI ignitors are $175 for a genuine honda ouch but lot better then $495 for a whole new distributor. Ive got one on order from acuraparts247.com he's gonna let me borrow one out of a used dist until mine gets here.
http://www.etrackmasters.com
Old Jun 11, 2005 | 10:56 AM
honda011's Avatar
your lucky... the same thing happend to me with my distributor, but i was on the turnpike and had to get towed home...
Old Jun 11, 2005 | 03:36 PM
sp00led's Avatar
Default Re: turbo integra died on me today (honda011)
i paid my dues, ******* hit me up for $50 for a tow about 4-5miles across town. Thank god the guy wasn't a retard he had blocks and a brain. When loading and unloading on flatbed nothing was damaged
Modified by redeyz at 5:36 AM 6/12/2005
Old Jun 11, 2005 | 04:09 PM
JeffRocksYoSocks's Avatar
**** happend to me on the way home from work. #3 spark plug wire came off then the coil burned.
BLU CIVIC
May 13, 2013 07:49 AM
EliTe 93Lude
Jul 20, 2006 07:46 PM
sl0w-m0
Jan 20, 2005 09:44 PM
KC GSR
Jul 21, 2003 05:12 PM
M.A.R.C.
Nov 9, 2002 09:32 PM
