Slave Cylinder Removal
CAUTION:
ˇDo not spill brake fluid on the car, it may damage the paint; if brake fluid does contact the paint, wash it off immediately with water.
ˇPlug the end of the clutch pipe with a shop towel to prevent brake fluid from coming out.
1.Disconnect the clutch pipe from the slave cylinder.
2.Remove the slave cylinder from the clutch housing.
3. Install the slave cylinder in the reverse order of removal. NOTE: Make sure the boot is installed on the slave.
BLEEDING THE SYSTEM
4.Bleed the clutch hydraulic system:
ˇAttach a hose to the bleeder screw, and suspend the hose in a container of brake fluid.
ˇMake sure there is an adequate supply of fluid at the clutch master cylinder, then slowly pump the clutch pedal until no more bubbles appear at the bleeder hose.
ˇRefill the clutch master cylinder with fluid when done.
ˇUse only DOT 3 or 4 brake fluid. We recommend Genuine Honda Super Duty DOT
ˇConfirm clutch operation, and check for leaking fluid.
CAUTION:
BLEEDING THE SYSTEM
there is only one way to make a slave cylinder burst that i can think of.... you have to compress the piston in the slave cylinder without giving the brake fluid room to escape (opening the bleeder vavle). There may be more ways to do it than that, but i'm not aware of them.
Changing the slave cylinder is the easiest thing you could possibly do. took me no more than 10 mins to remove and replace. maybe another 5 mins to bleed the lines. but you can depress the cylinder by using just your hand. depress and bolt it on. attach the line and then open the bleeder and pour fluid into the master cylinder and pump the clutch until you have restored pressure. tighten the bleeder valve back up and take it for a drive.
CAUTION:
BLEEDING THE SYSTEM
CAUTION:
BLEEDING THE SYSTEM
lo0nY
12
Jan 28, 2004 02:15 PM
