gsr engine harness into LS harness, few questions
Old Jun 9, 2005 | 04:20 PM
LS_DON4500's Avatar
Default gsr engine harness into LS harness, few questions
heres whats up, i recently dropped a b18c1 97 obd2 gsr motor into my 96 LS, i dont have my LS engine harness anymore, so the thing is im using a 99 gsr engine harness and plugging it into the LS ecu harness at the shock tower and serately running my knock sensor, vtec silinoid and Preassure swith for vtec, not hooking up IAB cause im runnin a skunk 2 intake manifold, the problems i have incountered are no power to the starter, ecu and fuel pump to prime, nothing happens, all grounds are hooked up, put a new main relay in it, checked all fuses they are fine, asside from runinng my wires from the engine harness for those thing directly to the ecu, is there anything else i need to do, i dont think it is getting the ground for the ecu that hooks to the thermo housing, it might be but just checkin, my main relay clicks when i turn the key over but no power anywhere, SO is there anything i need to do to the engine harness im using to make it work for my LS ecu harness or is it direct plug then run those wires seperatly, help would be appreciated, thanx for lookin
Old Jun 9, 2005 | 09:15 PM
LS_DON4500's Avatar
bump me up
Old Jun 10, 2005 | 12:13 PM
LS_DON4500's Avatar
hi again ttt
Old Jun 28, 2005 | 01:38 PM
intevic_dx's Avatar
me too. somebody answer.
Modified by intevic_dx at 10:50 PM 6/28/2005
LS_DON4500
Jun 8, 2005 09:32 AM
slayersluck
Feb 19, 2005 10:27 PM
silverb18
11
May 7, 2004 10:11 PM
SpoonyGSR
Jan 28, 2004 03:11 AM
DevinW
Aug 18, 2002 06:50 AM
