V-tec dizzy vs Non-Vtec dizzy
Old Jun 9, 2005 | 01:26 PM
som1_2race's Avatar
Default V-tec dizzy vs Non-Vtec dizzy
How are they different? If a dizzy is made to fire once its set then what would be the difference when vtec kicks in?
Old Jun 9, 2005 | 01:30 PM
DohcVtecCrx's Avatar
Default Re: V-tec dizzy vs Non-Vtec dizzy (som1_2race)
same internals, diffrent bolt pattern. I use an ls on my b16a, works fine but I had to cut one leg off and only 1 bolt on top.
Old Jun 9, 2005 | 01:41 PM
som1_2race's Avatar
I knew it! But would a OBD-2 vs 1 or 0 make a difference besides wiring or vtec?
Old Jun 9, 2005 | 01:46 PM
mr. carpenter's Avatar
Default Re: (som1_2race)
what dist. are you putting on what motor? your dist. needs to match your ecu.
Old Jun 9, 2005 | 01:52 PM
vegaskurt's Avatar
Default Re: (mr. carpenter)
From what I have read, you can use an obd2 dist on obd1 wiring. but you cant use an obd1 dist on obd0 wiring.
The rule of thumb is that the distributer should match the ECU you are running.
If Im wrong then someone please school me.
Old Jun 9, 2005 | 04:12 PM
Default Re: (vegaskurt)
your right. The obd-2 and obd-1 are the same, even the wiring is the same, they just (on obd-2) made the 2 plugs one. That is the only diffrence. Obd-0 is not compatable with anything other than obd-0. If your running an obd-0 ecu you must use obd-0 dizzy. You can use an ls one if you cut the leg off (only good if your in a bind cause 1 bolt can leak oil).
Old Jun 9, 2005 | 07:31 PM
som1_2race's Avatar
I know about OBD-2 working on OBD-1 but what I want to know is difference between Vtec & non-vtec dizzy's. My bro has a (non-vtec) TD80U on a z6 head.
Old Jun 9, 2005 | 08:19 PM
nothing
Old Jun 10, 2005 | 12:33 PM
som1_2race's Avatar
alright good..thanx
88EDHatch
Nov 12, 2010 11:27 AM
crxdonwon
Feb 19, 2009 05:53 AM
mymeatb18"
Oct 3, 2006 04:58 AM
gvillehnut
Mar 10, 2003 10:24 AM
