how to remove front hub? ADVANCED ADVICE NEEDED!!
Old Jun 9, 2005 | 11:52 AM
yh23's Avatar
Default how to remove front hub? ADVANCED ADVICE NEEDED!!
so I'm taking off the front hubs to have them replaced.
I was able to disconnect everything on the drivers side.
But now, I'm working on the passenger side, and the STEERING wheel bolt/ball joint wont budge and the upper control arm bolt/ball joint wont budge.
WTF. theyre both STUCK. I've tried hammering, using a jack, pulling, YELLING at it, threatening, jumping, punching, etc.
Any tips or ideas on getting the steering and upper control arm disconnected? Any cool trick?
Old Jun 9, 2005 | 11:56 AM
DC4_MADMAN's Avatar
Default Re: how to remove front hub? ADVANCED ADVICE NEEDED!! (yh23)
A ball joint splitter.
5-10 bucks at an auto parts store.
Old Jun 9, 2005 | 12:02 PM
IHateJDM's Avatar
Default Re: how to remove front hub? ADVANCED ADVICE NEEDED!! (4door_demon)
https://honda-tech.com/zerothread?id=887859
Nothing about this is advanced. It is a common prob though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yh23 &raquo;</TD></TR><TR><TD CLASS="quote"> YELLING at it, threatening, jumping, punching, etc.
I can't believe that didn't work .
Old Jun 9, 2005 | 01:54 PM
yh23's Avatar
thanks
Old Jun 9, 2005 | 01:56 PM
yh23's Avatar
Default Re: how to remove front hub? ADVANCED ADVICE NEEDED!! (IHateJDM)
oh, I know how to pop the lower balljoint.
im asking about the upper ball joint. i'll try that little balljoint tool....
Old Jun 9, 2005 | 08:56 PM
yh23's Avatar
bump...
anyone?
Old Jun 9, 2005 | 08:59 PM
nocturnaldragon's Avatar
Same thing I would imagine, take off the nut and drop it down. Thats how I did the one in my car if im thinking of the same joint.
Old Jun 9, 2005 | 09:08 PM
IHateJDM's Avatar
Default Re: how to remove front hub? ADVANCED ADVICE NEEDED!! (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yh23 &raquo;</TD></TR><TR><TD CLASS="quote">oh, I know how to pop the lower balljoint.
im asking about the upper ball joint. i'll try that little balljoint tool....</TD></TR></TABLE>
my bad, i must have misread it. i don't know of any tricks to the upper joint, i've never had a prob with it.
Old Jun 10, 2005 | 01:20 AM
yh23's Avatar
ya, usually it just pops out...but for some reason that upper control arm doesnt want to pop from the joint...damnit!!!
Old Jun 10, 2005 | 03:20 AM
litterbox's Avatar
I am a (Trial User) Army
If it really won't budge, you could just remove the entire upper control arm by disconnecting the two bolts that attach it to the shock tower.
Old Jun 10, 2005 | 10:32 AM
yh23's Avatar
Default Re: how to remove front hub? ADVANCED ADVICE NEEDED!! (litterbox)
yep...looks like i'll be removing the whollle thing....
spectastic
Honda Civic (2001 - 2005)
Feb 17, 2013 03:24 PM
crazykarlnow
Suspension & Brakes
Sep 1, 2007 10:32 PM
EK FLY
Mar 18, 2007 02:55 PM
Aphelion
Aug 3, 2005 10:01 AM
yh23
Suspension & Brakes
Jun 10, 2005 06:41 PM
