B16A2 swap. a couple of questions....need some help!
Old Jun 9, 2005 | 09:44 AM
Squallie's Avatar
Default B16A2 swap. a couple of questions....need some help!
ok, the car is a 89 crx Si and the motor setup going into the car will be a B16A2 with ITR head, ITR tranny, ITR intake manifold, stock internals. then i would ad on a K&N air filter on the stock piping, a greddy Sp2 cat-back exhuast system, and maybe DCheaders. now the questions. would this be a nice setup to boost later on? nothing to crazy but just enough for a daily driver and to take it to the track every now and then? and also, i plan on putting a short shifter on there but which application should i buy it for... the CRX or the ITR? im kinda lost on that part. so any and all info will be apreciated
Old Jun 9, 2005 | 10:08 AM
Squallie's Avatar
Default Re: B16A2 swap. a couple of questions....need some help! (Squallie)
bump! any suggestions on if i should change up the motor setup or not? or should i just stick with what i have
Old Jun 9, 2005 | 11:21 AM
Squallie's Avatar
ttt
Old Jun 9, 2005 | 01:41 PM
Squallie's Avatar
someone has to know
Old Jun 11, 2005 | 12:07 PM
Squallie's Avatar
couple days later bump
Old Jun 11, 2005 | 02:11 PM
PURPLETERROR aka BIGMATT's Avatar
Buy the shortshifter for whatever shift linkage you are running, as far as boosting down the line, what you have is fine, i wouldnt go over 10 psi without a good tune.
hondacivichatch
Sep 21, 2005 11:09 PM
Squallie
Jun 12, 2005 07:54 PM
tencan
Sep 26, 2003 12:14 PM
MeanGreenEG9
Jan 22, 2003 11:06 AM
