best intake manifold for all motor lsvtec
Old Jun 9, 2005 | 07:38 AM
nvmyb20hatch's Avatar
Default best intake manifold for all motor lsvtec
just looking for some words of wisdom from experience you guys might have had with different intake manifolds on your setups. i have a skunk2 manifold now, but if theres better manifolds out there, id like to know to maximize my power.
thanks
Old Jun 9, 2005 | 07:56 AM
Chillinit's Avatar
Default Re: best intake manifold for all motor lsvtec (nvmyb20hatch)
what head?
Old Jun 9, 2005 | 08:51 AM
hybrid_vtec's Avatar
Default Re: best intake manifold for all motor lsvtec (Chillinit)
What are you looking for: more top-end horsepower or more usable mid-range/topend horsepower.
Old Jun 9, 2005 | 08:52 AM
heres the specs of the motor:
arias sleeved b18b1
81.5mm arias 13.2:1 pistons
eagle rods & crank
portflow gs-r head
toda b cams
toda valvesprings, portflow retainers
dtr b-unit header
and i have the skunk2 manifold, but questioning whether i should go with something different besides throttle bodies
Old Jun 9, 2005 | 08:53 AM
Default Re: best intake manifold for all motor lsvtec (hybrid_vtec)
all around power, im tapped out at like 8600 with the todas im sure so im definitely looking to get as much low end punch as possible without completely eliminating power above say 8500
Old Jun 9, 2005 | 08:59 AM
97L-esVeeTeg's Avatar
JG sheetmetal, seems to work well, I have no personal experiance but have seen dynos and they look promising.
Old Jun 9, 2005 | 09:02 AM
Hrd to say then, b/c the Skunk2 may benefit you more being able to help you carry out that power to 8600. The B16 IM though will probably give you more all around power but will top out at about 8100 to 8200 on your setup. Just my opinion!
Old Jun 9, 2005 | 09:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">Hrd to say then, b/c the Skunk2 may benefit you more being able to help you carry out that power to 8600. The B16 IM though will probably give you more all around power but will top out at about 8100 to 8200 on your setup. Just my opinion!</TD></TR></TABLE>
I agree, the b16 seems to dominate in the mid-range and lose out above 8000.
Damn thats my 420th post, I'm never posting again
This may be to the delight of some of you on these boards
Old Jun 9, 2005 | 09:17 AM
Default Re: best intake manifold for all motor lsvtec (97L-esVeeTeg)
i had the toda b's in my b20vtec setup and my power fell off dramatically after like 8500. so im thinking its the todas that are preventing me from making power higher than that. the ls block is equipped with a golden eagle 3 main block guard, and its balanced and blueprinted, so it should be good for at least 9k, do you think i should just invest in some other cams, and stay with the skunk manifold?
Old Jun 9, 2005 | 09:37 AM
( o )( o )'s Avatar
also - does anyone have a pic or link to the JG sheetmetal IM? very curious to see what that's all about.....
Old Jun 9, 2005 | 09:46 AM
Default Re: best intake manifold for all motor lsvtec (( o )( o ))
ttt
Old Jun 9, 2005 | 06:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nvmyb20hatch &raquo;</TD></TR><TR><TD CLASS="quote">i had the toda b's in my b20vtec setup and my power fell off dramatically after like 8500. so im thinking its the todas that are preventing me from making power higher than that. the ls block is equipped with a golden eagle 3 main block guard, and its balanced and blueprinted, so it should be good for at least 9k, do you think i should just invest in some other cams, and stay with the skunk manifold?</TD></TR></TABLE>
Well that depends on preference! Me personally I like to have a strong power curve that gives me my max hp sooner than higher hp numbers later on in the rpm range.
I would go for what has the most avg horsepower for the area under the curve.
Old Jun 10, 2005 | 11:34 AM
well my motor will be assembled in like a week so once i get everything together, well see how the setup does. thanks for the help
Old Jun 10, 2005 | 11:43 AM
Phatch99's Avatar
don't forget to post up some dyno graphs.... good luck.
Old Aug 31, 2005 | 06:31 PM
john breezy's Avatar
Default Re: best intake manifold for all motor lsvtec (Phatch99)
shaun ill put you pics of the motor up soon...itb's were the proper choice
*bling*
Old Sep 8, 2005 | 09:35 AM
Default Re: best intake manifold for all motor lsvtec (john breezy)
holler i agree.*by the way i those twm 52mm itb's for me setup*
2k.civic.si
17
May 12, 2010 08:59 AM
chump2825
Aug 16, 2007 03:23 PM
b20vtecv8killer
Oct 22, 2004 05:40 AM
iH8BiTeRz
Apr 1, 2003 11:20 AM
civicR1
13
Apr 10, 2002 01:35 PM
