Swapped US ITR cluster into 97 GSR and gas guage won't work (searched)
Old Jun 9, 2005 | 02:57 AM
crazyitr's Avatar
Default Swapped US ITR cluster into 97 GSR and gas guage won't work (searched)
I installed my us type r cluster into my 97 GSR and the gas guage will not work. I had the same problem when I installed a type R cluster in my 92 EG. In the eg I simply put a obd 1 gas guage in the cluster and ended up with a different gas guage. Does anybody know of voltage differences between sending units or guages? Or is this just a coincidence?
Old Jun 9, 2005 | 04:15 AM
be.twenty's Avatar
did you also swap the green stuff in the back of the cluster?
Old Jun 9, 2005 | 08:03 AM
crazyitr's Avatar
Default Re: (shogun-dc2)
The green stuff is the circuit. Why wouldn't that stay with the cluster?
Old Jun 9, 2005 | 08:21 AM
be.twenty's Avatar
you want to take the old circuit board/paper from your GSR and attach it to your new ITR cluster. -- this is the easy way
the hard way is to take out the gauges individually and transplant them to your GSR housing.... basically, it's the same **** as transferring the green stuff but the more complicated way.
your call... i had to do the same **** when i installed an ITR cluster.
Old Jun 9, 2005 | 11:40 AM
DynastyRacer22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shogun-dc2 &raquo;</TD></TR><TR><TD CLASS="quote">you want to take the old circuit board/paper from your GSR and attach it to your new ITR cluster. -- this is the easy way
your call... i had to do the same **** when i installed an ITR cluster.</TD></TR></TABLE>
yea i agree alot of people who swaped there cluster into an itr you gotta swap the green paper
Old Jun 20, 2005 | 06:37 PM
94rs-turbo's Avatar
Default Re: Swapped US ITR cluster into 97 GSR and gas guage won't work (crazyitr)
hey the best way to do it is swap the actual gauges from your itr cluster to the stock gsr cluster dont even sway out the green sheet leave that alone just sway out the gauges
sunnybwoy
Jan 30, 2008 12:22 AM
Absentmind
Apr 27, 2006 03:28 PM
ME SO FST
Jun 2, 2005 07:31 PM
Hulkmanj99
Sep 16, 2004 09:24 PM
trooper0641
25
Apr 25, 2004 05:44 PM
