Where is the 2P connector to check the engine codes??
On my brother 90 DX HB we use it to troubleshoot the codes but on my cousins EF/si I cant located it at the same location? The previous engine was a B16A and he had a B18B1 dropped in so I got it running but have a code turning off & on..ANy ideas on the 2P connector?? What ecu pin out would they be it can be done off the ecu?? The ecu is a PR4(OBD-0) by the way.
On obd0 it flashes on the ecu led
drew2
Dec 3, 2005 11:51 AM
