91 crx dx smoking...where to start?
Old Jun 8, 2005 | 09:05 PM
slmd2ndgen's Avatar
Default 91 crx dx smoking...where to start?
Well, I noticed greyish smoke coming out of the rear of my car while driving fast...any suggestions on where to source this problem?
Old Jun 8, 2005 | 09:44 PM
crxnj's Avatar
Default Re: 91 crx dx smoking...where to start? (slmd2ndgen)
Are you sure it's grey..?? Not blue,white or black??
Or maybe your burning oil and coolant causing it to look grey??
Old Jun 9, 2005 | 12:37 AM
NikoZai's Avatar
Default Re: 91 crx dx smoking...where to start? (Mr.speaker)
haha if its for sure gray, smoke, smells like burning. It's your piston rings seeping oil. Make sure you watch the oil level to ensure you don't start to run low and burn up the engine further.
Look for a swap, you'll be better off anyway.
Old Jun 9, 2005 | 07:21 AM
slmd2ndgen's Avatar
thanks guys...I know it's not white(headgasket), but it's either grey or blue...I was really low on oil before going on the Julian Drive, the oil was barely registering on the tip of the stick. I put in 2 qts and the level was way above the 2nd hole in the stick...could I just have too much oil and it's burning "out"?!?!? before the CRXpo, I'd never noticed the smoke
Old Jun 9, 2005 | 02:11 PM
slmd2ndgen's Avatar
would too much oil do it?
Old Jun 9, 2005 | 02:13 PM
mr. carpenter's Avatar
Default Re: (slmd2ndgen)
way over the second dot is too much. the gap between the dots is approximatly 1 qt.
Old Jun 10, 2005 | 07:23 AM
slmd2ndgen's Avatar
good stuff...I must have had an 1/2 extra ct. if I remember correctly, well I'll keep an eye on it since I never noticed it until the this past weekend and I added too much oil coincidentally
Old Jun 10, 2005 | 07:45 AM
Sequoyah's Avatar
A compression and leak down test would be a good place to start. You can decide if it's worth it to fix the problem.
Old Jun 10, 2005 | 08:28 AM
CRseXxy's Avatar
sonds like 2 much oil.
Old Jun 10, 2005 | 04:50 PM
DA6Iceman's Avatar
we did that on the way to HIN last year with my wifes 97 and it smoked like a banshee.. it went away after a couple of days
Old Jun 11, 2005 | 07:01 AM
slmd2ndgen's Avatar
Default Re: (DA6Iceman)
Thanks for the help folks...I haven't seen it come back since about tuesday. Must have been too much oil
AntMan401
Aug 23, 2006 09:38 AM
chickenandpickles
16
Sep 11, 2005 01:29 PM
itsJDMyo
21
Jan 19, 2004 05:58 AM
civic2299
Oct 22, 2001 01:18 PM
QuickHonda
Sep 21, 2001 01:19 PM
